Cases that work with Tempered Glass Protector
  1. lastoneleft_00
    Froyo Nov 11, 2016
    lastoneleft_00 , Nov 11, 2016 :
    So after installing the tempered glass protector my case no longer works with my phone as it pushes up the edges of the screen causing it to form air bubbles. I have tried on 2 oneplue3 and both have the same issue after installing the glass. Has anyone found any cases that work with the tempered glass protector. I think its kinda crappy that they didn't take this into account when manufacturing the glass for the phone. Now I have nothing to protect the back or sides of my phone from getting scratched.
    Sainath jonnala likes this.
  2. sumeetsinghj800
    Eclair Nov 11, 2016
  3. siva.you
    Cupcake Nov 11, 2016
    siva.you , Nov 11, 2016 :
    No spigen cases won't suit...it is the one which causes more problem to tempered glass edge raising....but better try offline before getting one
  4. Peter Nyffels
    Peter Nyffels , Nov 11, 2016 :
    I use the curved tempered glass from one plus in combi action with the sandpaper back and they work fine
    At first I didn't got it right but the second time
  5. Deactivated User
    Nov 11, 2016
  6. SimonRam
    Lollipop Nov 11, 2016
    SimonRam , Nov 11, 2016 :
    Orzley v2 and nillkin flip case or orzley bumper case work.
  7. lastoneleft_00
    Froyo Nov 12, 2016
  8. pediocore
    Donut Nov 12, 2016
    pediocore , Nov 12, 2016 :
    Maybe you should change to Orzly 2.5D Tempered Glass SP. The glass fit most cases i tried. I have few Ringke Fusion, Otterbox Achiever and Sandstone Back cover, they fit just fine.
  9. Baibhav_Kumar
    Honeycomb Nov 12, 2016
  10. Sainath jonnala
    Cupcake Sep 23, 2020
    Sainath jonnala , Sep 23, 2020 :
    Do I really new a tempered glass for my 7T even after I have spigen case. I'm thinking to get gadget shield screen protector, removing the edge tempered glass
