cast is not working
  1. RAJESHNMH
    Cupcake Feb 19, 2020
    RAJESHNMH , Feb 19, 2020 :
    I have purchased lg7600 tv ,when I use app cast tv it was connected once with my phone but not it is not connecting
    Sunilkt713 likes this.
  2. Caomhin
    KitKat Feb 19, 2020
  3. RAJESHNMH
    Cupcake Feb 27, 2020
    RAJESHNMH , Feb 27, 2020 :
    even after enabling it is not working
  4. Sunilkt713
    Sunilkt713 , via OnePlus 6T , Feb 27, 2020 :
    hi this is Sunil I'm also facing same problem please resolve I have purchased l g tv I try to did cast screen but in my mobile not showing any near divices were found like that showing, in the mean time my brother mobile was showing and connecting also but I cont cast screen please resolve my problem.
  5. Caomhin
    KitKat Feb 27, 2020
    Caomhin , via OnePlus 6T , Feb 27, 2020 :
    So once you have connected your TV to your router, you do get the selectable option to Enable Wireless Display in the image below, but there is no TV listed to connect to as in the image below?
  6. Sunilkt713
    no i did that but it's not showing.
  7. Caomhin
    KitKat Feb 27, 2020
    Have you tried to set the TV up by ethernet cable to the router instead of Wifi, just to check if there is any difference
  8. pablofg1978
    Spanish POC Assistant Head Moderator Feb 27, 2020
    pablofg1978 , Feb 27, 2020 :
    You are not connected to any wifi, how do you think that will cast without any connection between your phone and tv
  9. Sunilkt713
  10. Sunilkt713
  11. Sunilkt713
    still not connect
  12. pablofg1978
    Is your TV and phone connected to the same wifi?
  13. Sunilkt713
  14. Sunilkt713
  15. pablofg1978
    Again, how do you suppose that you can cast to your TV if both devices aren't in the same network?
    Caomhin likes this.
