cast problem
  1. pankaj bhuva
    Cupcake Jan 21, 2017
  2. jmarcosk
    Gingerbread Jan 21, 2017
    jmarcosk , Jan 21, 2017 :
    Hi
    Did you get some error?
    What exactly are you trying to cast (app or screen mirror)?
    Did you Have a Chromecast or a Android TV?
    What O2 version are you running?
  3. OnePlusIrfan
  4. G_Udhav_Sharma_Egfi
  5. thambanurthamban
    Eclair Jan 21, 2017
  6. F_Mehardeep_Sawhney_MhPJ
    Donut Jan 21, 2017
  7. thambanurthamban
    Eclair Jan 22, 2017
  8. thambanurthamban
    Eclair Jan 22, 2017
    thambanurthamban , Jan 22, 2017 :
    oxygen 4.0.2, trying to connect via any view cast an option on smart tv
  9. G_Gab_Valledor_cSDg
    Cupcake Jan 22, 2017
    G_Gab_Valledor_cSDg , Jan 22, 2017 :
    same here cannot connect to smart tv
    1. same wifi network
    2. sony tv
    3. my other phone sony xperia z3 has no problem using screen mirroring with the same tv
    4. error encountered : registration failed.
    5. oxygen 4.0.2
    6. Android nougat 7.0
    what could be the problem? please help!
  10. sidcoolsid96
    Donut Jan 22, 2017
    sidcoolsid96 , Jan 22, 2017 :
    I also have a vu TV and I'm facing no such problem. Screen mirroring is smooth and no delays
  11. G_Gab_Valledor_cSDg
    you mean "cast" right? or did you download the app?
    are you already in nougat?
  12. jmarcosk
    Gingerbread Jan 22, 2017
    jmarcosk , Jan 22, 2017 :
    Screen Mirroring not always are Cast protocol, it is only between Android TV's and Chromecast's, all other TV's use Miracast, another protocol, that could be the issue here, try to update the TV software
  13. G_joseph_chain_lxyS
  14. wospino
    Honeycomb Jan 22, 2017
    wospino , Jan 22, 2017 :
    casting works very well, please take in mind that we TV's needs to activate casting or give permissions... like the LG smart TVs
  15. G_טלאור_אוחיו
  16. F_Chettawan_Senapant_Lur
    Gingerbread Jan 25, 2017
    F_Chettawan_Senapant_Lur , Jan 25, 2017 :
    Just notice that Miracast didn't work. Before 4.0.2 i usually cast OP3 screen to my LG smart TV using Miracast (it said on TV as Miracast signal detected). Now using the same method I cant cast my phone anymore. No error, the TV name just disappear from Cast menu when click connect. Already reboot both phone and TV didn't help.
  17. I am Chinese
    Eclair Jan 25, 2017
  18. NitinAnand
    Donut Jan 26, 2017
  19. rohitrajgupta
    Cupcake Jan 29, 2017
    rohitrajgupta , Jan 29, 2017 :
    I use to connect to VU TV with oxygen 3.2.8 using micracast not Chromecast, after 4.0.2 nougat update it didn't connect. while my other phone connect successfully. can someone suggest solution ASAP. if it helps I am using VOLTE. tried disabling VoLTE or couple of restart no luck ?.
    G_Gaurav_Jain_FHYc likes this.
  20. nitin_pandita
    Cupcake Feb 11, 2017
    nitin_pandita , Feb 11, 2017 :
    same issue with my vu smart tv. unable to cast my one plus3t or even one plus one :(
    while the YouTube is easily getting cast via the app
    kalpesh dedhia likes this.
