3
Cast/screen mirroring issue solved
  1. Ravindersamrala Eclair Dec 4, 2017
    Ravindersamrala, Dec 4, 2017 :
    hi oneplus fans
    Recently I updated my oneplus 3t to oreo and screen mirroring stopped working with my sony home theatre and smart tv as well. it showed connected but tv display was blank . I searched the community but there is no solution.
    after a lot of things I tried clearing data of 3 system apps that fixed the problem. Its working normally now. These 3 apps are WAPI CERTIFICATE, Wfd service and WifiRfTest.
    You can try as well If you are having problem with the cast.
    Go to settings> Apps> Applications list>show system app
    and scroll through the apps I mentioned above and clear data one by one. Hope it'll work for you as well.
  2. Ravindersamrala Eclair Dec 4, 2017
  3. Vedant620 Ice Cream Sandwich Dec 4, 2017
  4. P1512397185763 Cupcake Dec 4, 2017
    P1512397185763, Dec 4, 2017 :
    I don't s either any option like clear Data after all this settings> Apps> Applications list>show system app
    How did you do that??
  5. Ravindersamrala Eclair Dec 4, 2017
    try this ......settings>apps>applications list>show system app>wfd service> storage>clear data.......hope it'll help
  6. Ravindersamrala Eclair Dec 4, 2017
    yess and please let me know if it worked for you[e]1f44d[/e]
  7. G_Dev_Raj_oBBM Cupcake Dec 10, 2017
  8. Machorahul Honeycomb Dec 10, 2017
    Machorahul, Dec 10, 2017 :
    factory reset
  9. G_Sriharish_K_dqXW Cupcake Feb 3, 2018
    G_Sriharish_K_dqXW, Feb 3, 2018 :
    did factory reset solved screen cast issue? i am suffering from this on my oneplus 5. restrained from doing factory reset from a long time, but i don't see any other option
  10. pabhisek87 Cupcake May 12, 2018
  11. R1531147954051 Cupcake Jul 11, 2018
  12. usmangani_patel Froyo Oct 14, 2018
  13. F_Rahul_Sonawane_PEQM Cupcake Dec 25, 2018
  14. W1550749031159 Cupcake Feb 21, 2019
    W1550749031159, Feb 21, 2019 :
    I'm very late to the party, but this works every time for me.
    1. Go to apps > 3 dot menu > show system
    2. Find Wfd Service
    3. Click FORCE STOP
    4. Now try to connect to your TV
  15. LSB0007 Cupcake Jul 4, 2019
    LSB0007, Jul 4, 2019 :
    Tried everything. No fricking results.
    Sad.
    Model: A600
    Oxygen OS: 9.0.6
    OnePlus is shit if they can't fix this stupid issue
  16. Ravindersamrala Eclair Jul 5, 2019
  17. ghostofcain Marshmallow Jul 5, 2019
    ghostofcain, Jul 5, 2019 :
    There may be some hardware specific issues with your device try the forums for it rather than OP3(T).
  18. G_Л._Владимиро Cupcake Jul 19, 2019
    G_Л._Владимиро, Jul 19, 2019 :
    Really ?!!! How many times i i ha to factory reset?? YouTube ain't working the reset, now casting not working again reset... Sorry but i have 50 gb of local music and bunch of other stuff i cannot lose. So now even if i i send it to OnePlus for repair they r going to reset it...... ANY POSSIBLE OF NOT LOSING MY DATA PLS !???!?
  19. Nikithaareddi Cupcake Aug 14, 2019
    Nikithaareddi, Aug 14, 2019 :
    Hi ,
    @David Y.
    I am facing an issue with one plus 6T mobile cast option,
    Does One Plus 6T supports cast using Infrastructure Mode.
    Usually cast screen happens using two features one P2P (i.e: Wi-Fi Direct) and also the other using InfraStructure (Using Mobile Access point), can you please let me know if any settings need to be enabled for cast functionality to work using IF Mode but not through Wi-Fi Direct.
    Thanks & Regards,
    Nikitha.
