cast screen problem occuring
  1. B1563199445182
    Cupcake Aug 6, 2020
  2. Caomhin
    Marshmallow Aug 6, 2020
    Caomhin , via OnePlus 6T , Aug 6, 2020 :
    Make sure both are on the same Wi-Fi network, whether that be 2.4 or 5ghz.
    And make sure wireless display is selected as an option in the Cast app, 3 dot menu.
    If still not working, you may have to reset the WiFi on the phone.
    Settings, System, Reset Options, Reset WiFi Mobile Bluetooth.
    Do the same on the TV, but check the TV manual on how to reset TV WiFi.
    drl431 likes this.
  3. drl431
    Nougat Aug 6, 2020
    drl431 , Aug 6, 2020 :
    The Sony tv will also need to have its input set to Mirror.
    Caomhin likes this.
