Cellular Data problems after installing OxygenOS on OnePlus One
  1. KiLiBoSZ
    Gingerbread Jan 24, 2016
    KiLiBoSZ , Jan 24, 2016 :
    Hello,
    I've installed the OxygenOS 2.1.4. for the OnePlus One and sincen then, my Cellular Data speed is wasy too slow to send whatsapp messages. It takes about 30-45 seconds. I've installed the ROM NOT through TWRP. How to fix it ?
    Thanks, Kili
  2. SathiyXIX
    SathiyXIX , Jan 24, 2016 :
    Double check you have right apn settings. My apn settings and preferred network type where set to 3g and the wrong apn so I would only get H+ after changing APN settings and changing LTE all good
    Tokolozi likes this.
  3. 1ikhan
    Ice Cream Sandwich Jan 24, 2016
    1ikhan , Jan 24, 2016 :
    Google your service carrier's APN, and use that.
  4. KiLiBoSZ
    Gingerbread Jan 25, 2016
    KiLiBoSZ , Jan 25, 2016 :
    K, I've changed my APN and to LTE. It shows me that I have E, 3G, H+ or LTE but sometimes it just doesnt work. :( Dont know what to do.
  5. malidan
    Marshmallow Jan 25, 2016
    malidan , Jan 25, 2016 :
    You can try 1 of 2 things or return to your previous ROM.
    1. Reflash the ROM( clean )
    2. Find some radio files and flash then(different to the file in the update)
    Me personally I would flash another ROM and if its back to normal forget O2.
  6. KiLiBoSZ
    Ok. What or where are radio files ?
  7. Psk.it
    KitKat Jan 25, 2016
    Psk.it , Jan 25, 2016 :
    @KiLiBoSZ since AFH is down - try this way:
    unzip the rom, copy the content as is in a local folder (suppose c:\XYZ)
    reboot the OPO in fastboot mode, plug it to the PC
    on PC open a dos prompt as admin
    cd /d "c:\XYZ"
    c:\adb\fastboot flash modem .\firmware-update\NON-HLOS.bin
    c:\adb\fastboot flash sbl1 .\firmware-update\sbl1.mbn
    c:\adb\fastboot flash dbi .\firmware-update\sdi.mbn
    c:\adb\fastboot flash aboot .\firmware-update\emmc_appsboot.mbn
    c:\adb\fastboot flash rpm .\firmware-update\rpm.mbn
    c:\adb\fastboot flash tz .\firmware-update\tz.mbn
    c:\adb\fastboot flash LOGO .\firmware-update\logo.bin
    c:\adb\fastboot flash oppostanvbk .\RADIO\static_nvbk.bin
    c:\adb\fastboot flash boot .\boot.img
    c:\adb\fastboot oem unlock
    c:\adb\fastboot reboot
    -- N.B.: ensure all paths are correct before start flashing
  8. malidan
  9. SathiyXIX
    SathiyXIX , Jan 25, 2016 :
    What carrier are you with?
  10. KiLiBoSZ
    I have done all steps but it just reboots me into TWRP...
  11. RohitSole
  12. yetiweston
    Ice Cream Sandwich Jan 25, 2016
    yetiweston , Jan 25, 2016 :
    Yes, very easy
    RohitSole likes this.
  13. RohitSole
  14. yetiweston
    I normally root as soon as I get a phone, be brave and once you have the OTA give it a go
  15. RohitSole
    Gingerbread Jan 26, 2016
    RohitSole , Jan 26, 2016 :
    Hmm letz see , can u give me Text/video tutorial link of rooting
  16. yetiweston
    Ice Cream Sandwich Jan 26, 2016
    yetiweston , Jan 26, 2016 :
    Not got the link to hand but if you do a quick search on here you will find it, when i get 5 minutes in work i will have a look for you
  17. yetiweston
