change manual lock
  1. G_Saheb_Sachdeva_acMu
    Cupcake Oct 20, 2017
    G_Saheb_Sachdeva_acMu , Oct 20, 2017 :
    Phone unlocks as soon as i swipe, while I have set the pin, however there is an icon which needs to be pressed so as to set the lock pin, how to change the same
    the.unknown likes this.
  2. the.unknown
    Eclair Oct 20, 2017
  3. G_Saheb_Sachdeva_acMu
  4. B1530293740144
    Cupcake Jul 9, 2018
    B1530293740144 , Jul 9, 2018 :
    how to disable the lock sign so that the device doesn't open without asking for a pin or pattern? I am facing the same issue. I just want to disable the manual lock system so that I don't need to press the lock button to lock the device.
    And disabling the smart lock won't keep my device secured as I will no longer have pin or pattern lock or even finger print.
  5. the.unknown
    Eclair Jul 9, 2018
    the.unknown , Jul 9, 2018 :
    You need to go to Security and Privacy -> Smart Lock in settings and then disable every smart lock options like on-body-detection.
    This will disable your smartlock only but you will still have your pin and fingerprint as security method.
    B1530293740144 likes this.
  6. B1530293740144
    Cupcake Jul 9, 2018
    Thank you so much! It worked.
  7. Z1560022077451
    Cupcake Jun 13, 2019
    Z1560022077451 , Jun 13, 2019 :
    Thanks for solution. I was also having same issue. Everytime I needed to tap on lock to lock mobile. but thanks to you it can now auto lock. [e]1f618[/e][e]1f618[/e]
