Changing the font
  1. nahaluk
    Froyo Aug 9, 2014
    nahaluk , Aug 9, 2014 :
    Hi, I was wondering if there is way a to change the font of the phone. In my Note I used an app that gave me an infinite choice of fonts. They don't work with the One, there is no option in settings to change the font.
    My other question is how to make a backup for the Trebuchet launcher.
    And my last question is how to import my own ring tone. I tried to use my usual mp3, but I couldn't set it as a default ring tone.
    1Marya likes this.
  2. mattc
    Jelly Bean Aug 9, 2014
    mattc , Aug 9, 2014 :
    You can go in the theme settings and choose the font from the theme you want.
    For the ringtones, I had the same issue at first. You need to put your mp3s in a Ringtones folder (create it in the sdcard folder)
    Axara, ronoldo, kp1234 and 1 other person like this.
  3. UnknownSoul
    UnknownSoul , Aug 9, 2014 :
    1. There's a font section under themes.
    3. Don't let android system set the tone. Or do as posted above.
    kp1234 likes this.
  4. nahaluk
    Froyo Aug 9, 2014
    Thank you, is there a way to import fonts into theme or launcher? Because the launcher I have doesn't have the font I like.
  5. kp1234
    Community Veteran Aug 9, 2014
  6. nahaluk
    Froyo Aug 9, 2014
  7. Dav8v8
    Gingerbread Oct 25, 2014
    ronoldo likes this.
  8. qjoher
    Cupcake Dec 30, 2014
    ronoldo likes this.
  9. Rhonda Jenkins
    Donut Dec 30, 2014
  10. varunahuja_87
    Donut Apr 27, 2015
    varunahuja_87 , Apr 27, 2015 :
    Hi - I recently downloaded and installed HiFont. I changed the font and then deleted the app after a few days. The font that I had downloaded did not get deleted alongwith the app. I have tried resetting my theme too. Nothing changed. Anyone help?
  11. luisafm
    Cupcake Apr 29, 2015
  12. shwatt77
    Gingerbread Apr 29, 2015
    shwatt77 , Apr 29, 2015 :
    I use ifont. It's great. Just download app from play store.
    satilathehun likes this.
  13. Everett
    Cupcake Dec 13, 2015
    Everett , Dec 13, 2015 :
    I just downloaded that app to and it says that I have to root the phone.
