Charge problem
  1. Aron Gustafsson
    Froyo Mar 13, 2019
    Aron Gustafsson , Mar 13, 2019 :
    Hi,
    I just got some problem with charging my oneplus 6 after a drop to the floor from 1meter while it was charging. I have tested another dash charger and it won't work either. It will just show a red led light on the top of the screen but nothings apers on the batteri icon.
    The weird thing I noticed that if the phone is completely off and the charger is put in the phone starts for 1sec and then shuts down again and then starts for 1 sec and the shuts down again, it just go off and on in a regular motion. It seems kind of weird. I have reset the phone completely as well. But my question is. Does anyone know if there might be some problem with the charger inputs, so I just need to change it or is it possible that it can be the motherboard?
    Very kind for answers
    //Aron
  2. gazz1701
    Jelly Bean Mar 13, 2019
    gazz1701 , Mar 13, 2019 :
    Sounds like you may have damaged your phone - best to contact support and try to get fixed, although if any signs of the drop it may cost to get repaired.
    Neddard and Deactivated User like this.
