charger cable burn automatically via OnePlus 6T
  1. Bhuwan chand
    Cupcake Feb 24, 2021
    Bhuwan chand , via OnePlus 6T , Feb 24, 2021 :
    hi oneplus forum my oneplus 6t charger ban automatically e I am attaching the picture with you guys please help me what should I do next sometime my charger cable getting hot while charging the phone I am scared my phone might burn or blast someday pls guide me what to do
  2. Arjun_Choudhry
    KitKat Feb 24, 2021
    Arjun_Choudhry , Feb 24, 2021 :
    That's a tear or cut.
    Cable and charging adapter do get a little hot while charging, as the whole charging system generates heat there. Check the working of Dash charge or VOOC
    Tobikage and Auristic like this.
  3. B_Wrath
    Nougat Feb 24, 2021
    B_Wrath , Feb 24, 2021 :
    That looks like a cut more than a burn.
    Don't use it. Replace the cable.
  4. Bhuwan chand
    Cupcake Feb 26, 2021
    Bhuwan chand , via OnePlus 6T , Feb 26, 2021 :
    no it's burn only..no tear no cut... now
    I'm charging with it it's become so hot
  5. Bhuwan chand
    now see... pls tell what could be the reason of burning
  6. Bhuwan chand
    Hey bro.pls see now
    why I will cut..my charger
  7. Cervantes
    Moderator Moderator Feb 26, 2021
    Cervantes , Feb 26, 2021 :
    Hello
    You have the charging cable broken, You need to change the cable, as it says:
    https://www.oneplus.in/store?from=head
    Please, Use the search engine before opening a new thread: Search
    Read the forum rules: Rules
    Thread moved support
    Shailender Sharma, Liehjan and KluGe like this.
  8. Liehjan
    Marshmallow Feb 26, 2021
    Liehjan , Feb 26, 2021 :
    An electrical peak or something... But what ever it is that caused it, stop using the cable now!
  9. Raza_Dawar
    Gingerbread Feb 26, 2021
  10. Arjun_Choudhry
    KitKat Feb 26, 2021
    Arjun_Choudhry , Feb 26, 2021 :
    Nobody says you did it intentionally. Even so, rolling up the cable for extended periods and then straightening it repeatedly leaves similar damage to cables. The blackening of the cable is due to corrosion of the copper that you can see. As it is, the cable is carrying high current, so exposure to air and incorrect insulation (the cut in your case) can lead to sparking. So buy another one at the earliest.
    Sushant_Patil556 likes this.
  11. Bhuwan chand
    thanx for the prompt reply.. I have ordered new one
  12. Sushant_Patil556
    Froyo Feb 26, 2021
    Sushant_Patil556 , via OnePlus 6 , Feb 26, 2021 :
    Yes it is not intentional , it may be due to regular wear and tear.. just get it replaced ☺️
  13. Sushant_Patil556
    Froyo Feb 26, 2021
  14. sumitMZ007
    Jelly Bean Feb 26, 2021
    sumitMZ007 , via OnePlus 6 , Feb 26, 2021 :
    It's wear and tear which happens due to rough use! You can buy new one and I think it won't create heating Issue besides the charger getting little bit hot! Using a broken wire is dangerous ⚡⚡!
