Charger replacement alternatives
  1. Mazan Ace
    Cupcake Nov 11, 2019 at 2:56 AM
    Mazan Ace , Nov 11, 2019 at 2:56 AM :
    So I recently lost my original charging adapter for my OP 6T and I want a good one but I cannot afford the original adapter for 1.5k inr. So instead, I'm thinking of buying a Vooc charging adapter for real me X. Can you tell me if this would be a good choice? and what would be the side effects?
    Could you recommend a charger?
  2. masqu
    Eclair Nov 11, 2019 at 3:22 AM
    Mazan Ace likes this.
  3. Bilalazeem54
    Honeycomb Nov 11, 2019 at 6:13 AM
    Bilalazeem54 , via OnePlus 6T , Nov 11, 2019 at 6:13 AM :
    The phones circuit will only take the current power it states, sometimes for bad luck your phones charging IC could burn after a while of use with the VOOC. for eg. plugging a flash drive into a phone charging adapter result... it shorts
    to be on safe side, use current thats required or lower.
    Mazan Ace and Kytharsis like this.
  4. JustAPhone
    Ice Cream Sandwich Nov 11, 2019 at 8:16 AM
  5. Mazan Ace
    Cupcake Nov 12, 2019 at 2:03 AM
    Mazan Ace , Nov 12, 2019 at 2:03 AM :
    oh thanks... could you recommend one?
  6. Bilalazeem54
    Honeycomb Nov 12, 2019 at 2:05 AM
  7. Mazan Ace
    Cupcake Nov 12, 2019 at 2:26 AM
    Bilalazeem54 likes this.
