Tl;dr charge your phone overnight while it is turned on
stop wiping caches
stop using weird battery calibration methods
A lot of people have many misconceptions about wiping caches and many other things (I believe you read the title already so you know what this is about)
What makes the thread different from others?
I would like to make this the most complete thread out there that explains everything to the user about what is happening with their device so that I can get full marks for this assignment
Wait what are you talking about? What assignment?
Exactly! I intend to do exactly the opposite of that. Most threads on this forum give too much information to the user with too little explanation of things or give users information about irrelevant but related things
It's as if you have to write some assignment and you're just writing for the sake of writing
That is what I want to avoid here. No "completeness" here
One more thing. Many people claim to understand everything they read on many articles.
I will make one thing clear:
If after reading this article you think you have understood every word of it then you understood nothing at all. Go through the article again if that is the case.
This isn't a thread where you will just get the "solution". Think about why the issue occurs and not how to solve it. If you don't want to think that way then leave this thread
So on to the main thing:
What is a cache and why is clearing it is my blind faith:
Definition:
According to wikipedia cache is.........
aaaand skip
we are done here. for the definition just go to
https://en.wikipedia.org/wiki/Cache_(computing)
Why do you want to clear the cache?
Good question. If any one of these conditions are met you should definitely wipe cache:
1) You are bored and have nothing to do
2) You don't have battery drain but you want it so that you can bug everyone on the forum
3) You have no issues with performance but you want stutters and lags so that you can show others how bad oneplus is
4) You want your device to charge very slowly and be very hot during charging
5) You need a hand warmer
6) You want to wait weeks for the cache to rebuild and during this time period you want to face all the aforementioned issues
If any of these conditions are satisfied yeah sure go wipe the cache
So why is wiping the cache so bad?
image credit:
https://www.xda-developers.com/samsung-galaxy-note-5-marshmallow-system-dump-available/
image credit:
https://www.recoverandroid-data.com/blog/fix-android-is-starting-optimizing-app-error
note: information given in that link is incorrect
These images seem familiar? I'm sure you've seen them all during a system update
So what is the big deal? Didn't android N remove this?
Wrong. Android N did not remove this screen but merely postponed the task and the deferring of this task is what's causing your battery drain
So is it optimising in the background?
Wrong again. This optimisation is only triggered during a very special case. It is the lack of this optimisation that causes your battery drain
Yes you read it right. The optimisation is not performed because the user does not know how to satisfy the condition required for the optimisation to start
The result:
Image credit: The android soul
notice android system taking 17% just for itself? That is what happens when you do not let this optimisation complete
Now comes my first forum post about this which says:
"I'll explain why you get battery drain after a system update, factory reset or clearing the cache
If you've ever owned a device with Android 6 or lower you might be very familiar with the optimising apps screen. Well android 7.0 added a feature to skip that optimisation and use the JIT and the interpreter to optimise apps on the fly. The code running behind the optimising apps screen wasn't removed however, it was instead run when a very specific condition was satisfied (device is plugged in, charging, full battery, turned on, is not in use and is not in motion)
If all these conditions are satisfied the optimisation begins
Now we get to the battery drain part
Before you read further keep this in mind. The optimisation when the phone is idle is handled by AOT. JIT analyses the app and sees which parts are called frequently and passes a JIT profile to AOT for compilation
Remember that AOT can only use the JIT profile, anything else optimised by JIT is useless for AOT
The issue here is: when you do any of the things I said above like a system update, only the JIT is running (actually it is helping the interpreter) and it's optimising apps on the fly. If it's going to optimise apps as you open them it's going to have a lot of processing overhead and this is going to heat up your device a lot and drain a lot of battery
The solution: plan when you want to do a system update. You should preferably do the system update 2 hours before you sleep so that you can leave your phone connected to a charger to allow this initial optimisation phase to pass
The other advice is to not wipe your cache often"
https://forums.oneplus.com/threads/closed-battery-performance.911024/#post-19181266
Now there are some people who will ask what the solution is
To those people here is my answer:
1) It is given right there in the quoted message. Read
2) change your approach. read the bold text at the start of this post. do not ask for the solution but try to find out why the issue occurs in the first place
Now the second myth:
"Wiping cache makes my phone boot faster! You are lying!"
Busted:
"When you boot the first time after a system update/cache wipe, the phone analyses which parts of the apps and system are slow to compile directly on the CPU
So it writes out a profile and on the second boot, android picks up this profile and pre-optimises those methods, causing that second boot to take longer
If you wipe caches, you are basically forcing the system to redo this
Myth: after a system update, old cache is redundant and must be thrown away
Fact: android compares the old cache against the boot.art in /system and if it doesn't match, the entire cache is discarded so manually doing it is no different"
https://forums.oneplus.com/threads/one-plus-5-lags-after-9-0.974976/page-3#post-19739199
In other words wiping cache might make the first boot after wiping it fast but your actual performance and battery life will suffer
We are done about battery and performance myths
To sum it up:
JIT:
poor performance
high resource usage
high power usage
low runtime performance
compiles quickly and can make the system and the apps available to the user faster
easier to exploit compared to AOT (source: android hardening project/KSPP/linux-hardnened/copperheados)
AOT:
very high performance
lower resource usage since a compiler/interpreter is not active during execution
lower power consumption
very high runtime performance
compiles very slowly. some apps like google play services can take anywhere from 20 minutes on an op6 to 45 minutes on an op2
significantly harder to exploit compared to jit
why is this optimisation needed in the first place?
app developers cannot optimise their app for every device and every hardware and software combination out there so the obvious solution is to make one app that can run on every device. However it is inefficient as it is not optimised for your cpu and processing is needed so that the cpu can understand it. Interpreting every time you launch an app is slow and puts a lot of load on the cpu
Myth: cache is rebuilt immediately after cleaning
Wrong. cache can take anywhere from a few hours to even a few weeks to regenerate and while it does you will face severe battery drain
Diagnostic test:
I told 2 people to do this
The first was to keep their phone connected to a charger for a week and just leave it idle
The second was told to use his device but was told to charge it to 100% only when turned off and never charge when turned on
You would say the first device would have bad battery? Wrong
The device you think was mistreated actually had the best battery performance and was smooth
To keep the test fair: both devices were used almost the same after the experiment was over
both devices were on wifi and airplane mode was enabled
both devices had the same apps installed
both devices had dm-verity in enforcing mode
both devices were encrypted
The first device:
The second device which you thought will have the best battery life and performance:
do you want to still say wiping cache helps
now it's time for an official article written by google:
https://source.android.com/devices/tech/dalvik/configure
Had enough proof? Oh wait
"Doesn't charging your phone to 100% damage the battery?"
I quote an electrical engineer:
Now my 2 cents:
Let us say the battery does get damaged when you charge to 100%
If the optimisation does not complete you will have terrible battery drain anyway
So what do you get out of this? Peace of mind? Poor performance? if it is as you say then neither way will you get the battery and the poorer performance comes with it as a bonus
Busting cache partition myth:
The cache partition is a partition on android that stores temporary files and these are useless.....
WRONG. COMPLETELY WRONG
What the cache partition really does:
"I have also busted the cache partition
The cache partition is useless while booted to android and selinux blocks android from writing to /cache or even knowing that the cache partition is present
The cache partition is used only when booted to recovery, incremental OTAs will copy a block of the partition the script is patching, compute the patch on /cache and copy it back to the partition being patched
The reason for doing so is that the cache partition can store the overall progress of the update so by using it if a user interrupts a system upgrade, the bootloader will read the misc partition, boot recovery and recovery will read misc (or /cache. Thanks to
@elanglois for the correction!)
The recovery will then read the contents of /cache and reverse the system update because it has the last version of the block/file that it was patching in case something goes wrong. It will then start the system upgrade again
The cache partition doesn't even store the OTA, the OTA is stored on data. Uncrypt is used to decrypt the blocks of data containing the OTA/if using file based encryption the encryption policy is modified to allow the recovery to read the OTA
Since the cache partition is not encrypted, storing anything here is serious information disclosure and while booted it serves no purpose.... It's just there
A/B partition scheme did not require such a failure recovery mechanism and the cache partition was dropped
The cache partition is always empty. There is nothing to wipe"
Myth: oneplus 6 removed the cache partition so.........
Stop right there. In the absence of a cache partition android's vold uses /data/cache and it is usually bind mounted to /cache
Now some stupid ROMs do place something called an openrecoveryscript in /cache to flash instead of using the misc partition. Stay away from these ROMs. They do not know what they are doing
If a developer/maintainer tells you to wipe caches/clean flash every build then that developer/maintainer/whatever is not really what he claims he is and knows nothing about android
moving on
what is battery calibration?
"Just because the whole world does something does not mean it is right"
It is a stupid myth and I already have a thread about it here:
https://forums.oneplus.com/threads/battery-calibration-time-to-destroy-this-age-old-myth.833209/Click to expand...
