Charging cable
  1. Msb12
    Cupcake Oct 24, 2020
    Msb12 , Oct 24, 2020 :
    Can I use my old Dash charging cable with 30 Warp Charger, or do I need a special Warp charging cable? I can use the 30warp to charge 8T, it will just be at a slower rate than 65warp?
    The 65 is out of stock and I need extra charger, and have alot of dash cables.
  2. lukasp.
    Froyo Oct 24, 2020
    lukasp. , via OnePlus 8T , Oct 24, 2020 :
    The warp charge cables will work, but can only charge the warp charge speeds. So the 1+ 8t is backwarts compatible with older chargers (the max. Output is printed on the plug). And not charging at those 65 watt your battery will last longer.
  3. Msb12
    Will Dash charge cable work with Warp Charger? I am upgrading from 5t, so have a bunch of dash cables.
  4. lukasp.
    Froyo Oct 24, 2020
    I upgraded from a 5t too! The chargers are different: 5t had a USB-c to USB A (full size usb) cable and then the plug with usb A. The 8t has a usb-c to usb-c cable and a usb c wall plug.
  5. lukasp.
    Froyo Oct 24, 2020
    The left one is the 8t charger and the right one my 5t charger. You can't use the brick of the 5t with the 8t cable or other way around. (Since I am from the EU I might have a different looking plug for the wall)
  6. Msb12
    I meant can I use dash cable with the older 30W Warp charging brick, which has USB? I was going to order 30w since the 65W is out of stock, and need extra charger. I didn't know if need to order the Warp cable also, or if my dash cable would work with 30W brick.
  7. lukasp.
    Froyo Oct 24, 2020
    The dash charge brick and dash charge cable do work on the OnePlus 8t. They only do the dash charge power so not 65 watt but it is still pretty fast
  8. Msb12
    And dash charge cable will work on Warp 30 brick, or is there something special about Warp cable?
    Thanks for all replies
  9. Msb12
  10. Msb12
    How do you like the 8t compared to 5t?
    I haven't used my 8t yet
  11. lukasp.
    Froyo Oct 24, 2020
    Feels like using the future! Super smooth display, waay better colours. Really love to use the phone. And it has awesome standby battery management
  12. Bharamdev
    Froyo Oct 24, 2020
    Bharamdev , via OnePlus 8T , Oct 24, 2020 :
    I have had this question on my mind since the time I bought the 8T. I usually don't like borrowing someone else's charger, so I plan to leave my old 3T's 20W Dash Charger in office and use it if need be and I know I won't get crazy 65W charging speed but that's fine. I did try charging the 8T with 3T's dash charger. During the test, the surface temperature of the phone was 36 degrees. The Dash Charging adapter however was around 42 degrees.
  13. P1606238957083
    Cupcake Nov 24, 2020
    P1606238957083 , via OnePlus 5T , Nov 24, 2020 :
    Can i use any ucb c cable with my dash charging brick to charge my OP 5t?. Will the charging be slow or will it be the same if i don't use the cable in the box.
  14. 2pints
    Ice Cream Sandwich Nov 24, 2020
    2pints , Nov 24, 2020 :
    Good Question, just to add a little more detail..... Previous OP phones required you to use a genuine one plus or Dash charge compatible cable, does the *T have this requirement or can you charge at full speed with any PD 60Watt compatible USB type C to Type C cable?
  15. Xpress0
    Gingerbread Nov 26, 2020
    Xpress0 , via OnePlus 8T , Nov 26, 2020 :
    I tried using the 65W charger with my 30W USB cable with a USB-c to USB-A adapter and Warp charge is working exactly like when using the cable coming with 65W
