Charging disconnects issue via OnePlus 8T
  1. the_crazy_shady
    Gingerbread Jan 19, 2021
    the_crazy_shady , via OnePlus 8T , Jan 19, 2021 :
    Everytime i plug in for charging, the phone starts and disconnects charging on it's own for more than 4-5 times until it finally starts charging..
    The charging animation also doesn't work anymore since past 1 month.
    Tried clearing cache still it doesn't work..
    Any solutions?
  2. siriokds
    Froyo Jan 24, 2021
    the_crazy_shady likes this.
  3. puccellino
    Lollipop Jan 24, 2021
    puccellino , Jan 24, 2021 :
    Does it actually physically stop charging, or does the animation show disconnection?
    If so, check your connection port for fluff and dust.
    eastbay likes this.
  4. the_crazy_shady
    Gingerbread Jan 24, 2021
    the_crazy_shady , via OnePlus 8T , Jan 24, 2021 :
    Thank you.. i got the solution
  5. Nayan Sindhav
  6. eastbay
    KitKat Jan 25, 2021
    eastbay , via OnePlus 8T T-Mobile , Jan 25, 2021 :
    First clean both ends of plug in wall make sure it's proper connection. Then check the USBc going into phone clean that also. If provider is nearby go try his charger. Then you should know if charger is no good.
  7. #8
  8. Pravin2999
    Gingerbread Feb 5, 2021
  9. #10
