Charging From A Standard USB Output via OnePlus 8 T-Mobile
  1. ksnwireless
    Donut Aug 2, 2020 at 1:38 AM
  2. hahaha2223
    Jelly Bean Aug 2, 2020 at 1:40 AM
  3. Cheezburgers
    Froyo Aug 2, 2020 at 1:44 AM
    ksnwireless likes this.
  4. ksnwireless
    Donut Aug 2, 2020 at 5:38 AM
    ksnwireless , via OnePlus 8 T-Mobile , Aug 2, 2020 at 5:38 AM :
    hahaha2223
    Yeah, it's called universal for a reason.​
    If the device is designed for ONLY a quick charge at 4.5 amps, then a universal charger will not work. It won't hurt the phone, however, the universal charger may be destroyed due to heat. In other words, the universal charger may not be very universal, if the charge circuit in the device doesn't recognize it's a universal charger.
    Please don't give bad information unless you're educated on the subject.
    Thanks you!
    Skugen and Neerajan like this.
  5. hahaha2223
    Jelly Bean Aug 2, 2020 at 9:36 AM
    hahaha2223 , via OnePlus 8 Pro , Aug 2, 2020 at 9:36 AM :
    I don't know where you got that quote, but it is bullshit, why would something heat up when you draw less power?
    Btw, why would you ask a stupid question on a forum and then go and act smarter than the people that answer?
  6. ksnwireless
    Donut Aug 2, 2020 at 12:31 PM
    ksnwireless , via OnePlus 8 T-Mobile , Aug 2, 2020 at 12:31 PM :
    The phone draws the current, and if the phone is UNABLE to reduce its current flow, or any device for that matter, and you use a charger that's to small to handle the amount of current being pulled, heat will result with possible charger failure. The same goes for the charging cord. If to small for the current flow, it too will heat up and possibly fail.
    I bet you use pieces of aluminum foil in place of fuses. Well, a basic electronic genius you're not, so please keep your opinions to yourself. This by no means is a stupid question.
    Again, will the device see that it's a 1A charger instead of the larger stock charger provided, and switch to safely charge?
    Oh, by the way, your welcome for the lesson.
  7. hahaha2223
    Jelly Bean Aug 2, 2020 at 12:49 PM
    hahaha2223 , Aug 2, 2020 at 12:49 PM :
    Well then genius, why would a phone not be able to reduce its current draw to 1A?
    It is supposed to be charged from computers, which are only designed to deliver 0.5A. (or that's most you can safely expect)
    Chargers also communicate their max charging speeds in some ways, so unless you have an ultra shady Chinese adapter it should be safe enough to use, the phone will only start to draw the warp charge power once it has communicated with the charger that it is, in fact, a warp charger.
    How you ever made it a donut, god knows, cuz this is definitely a cupcake question.
    And of course, aluminium foil is the best kind of fuse </s>
    And because this is becoming a thread of petty insults, *you're
  8. Cheezburgers
    Froyo Aug 2, 2020 at 6:26 PM
  9. Himanshuchamoli
    Froyo Aug 2, 2020 at 7:55 PM
