Charging Glitch
  1. moses4747
    Cupcake Feb 25, 2020
    moses4747 , Feb 25, 2020 :
    My phone almost less than a year old and has recently started to consistently switch from rapid charge to normal charge like glitching .... causing phone to take a long time to charge ....
    I tried charging with different cables different chargers ..
    my findings narrowed down to either hardware issue (my worst fear)
    or software issue ....
    the battery life is performing well and there are no other issues that may be correlated ...
  2. Bilalazeem54
    Ice Cream Sandwich Feb 25, 2020
    moses4747 and Caomhin like this.
  3. Liehjan
    Lollipop Feb 25, 2020
    Liehjan , Feb 25, 2020 :
    Check the usb-port on the phone, is there dust? if so use compressed air or a vacuum cleaner to remove it
  4. moses4747
    Cupcake Mar 13, 2020
    moses4747 , Mar 13, 2020 :
    Update:
    I just received an update and the problem seems to be solved now.... the dash charging is on point ant uninterrupted (touchwood )
    but I am not using my original cable anymore....
    this was confusing period for me as there was no way to be sure whether it's a hardware issue or software issue....
