Charging issue in one plus 6
  1. Dr Chitra Cupcake Jul 3, 2019
    Dr Chitra, Jul 3, 2019 :
    I am facing charging issues with one plus 6
    From some days whenever I charge my phone there occours an issue with interrupting charging
    As I switch it on the plug of charger for few seconds it displays fast charging and then gets disconnected. Again it shows the fast charging again it disconnects. This thing goes on spontaneously sometime...
    Can someone please tell me the solution
  2. Kytharsis Marshmallow Jul 3, 2019
    Kytharsis, Jul 3, 2019 :
    Clean out the charge port and check to see if the charging cable is damaged in any way.
    ironass, drl431 and buntycubal like this.
  3. Dr Chitra Cupcake Jul 10, 2019
  4. Dr Chitra Cupcake Jul 17, 2019
    Dr Chitra, Jul 17, 2019 :
    Can anyone please let me know if there is any solution still facing the same thing...
  5. drl431 KitKat Jul 17, 2019
    drl431, Jul 17, 2019 :
    You would need another charger and cable to eliminate those possibilities. After that, if the phone still does not charge properly, it would need to go to a service center.
    Kytharsis likes this.
