Charging issue in one plus 6t via OnePlus 6T
  1. P1567672199868
    Cupcake Oct 17, 2021
  2. Dresa91
    User of the Year 2016; Most Active User 2020 Community Expert Oct 17, 2021
    Dresa91 , Oct 17, 2021 :
    1. Can you please clean the USB port of the device and check via settings - battery, if optimized charging is enabled. If yes, please disable it.
    2. clean the USB port of the device and pc and then check again. Try another cable.
  3. P1567672199868
  4. Dresa91
    What do you mean with: in 6 everything is working fine?
  5. P1567672199868
  6. Dresa91
    Okay.
    Did you check it?
    drmartin likes this.
  7. P1567672199868
  8. Dresa91
    Did you try another charger, cable or socket?
  9. P1567672199868
    P1567672199868 , via OnePlus 6T , Oct 17, 2021 :
    Yes I have tried and phone had supported the fast charging. But now it is not happening. Even my pc is not recognising the phone has been connected.
  10. Dresa91
    Also with the other charger or cable?
  11. P1567672199868
  12. Dresa91
    And you already cleaned the USB port?
  13. P1567672199868
    Cupcake Oct 21, 2021
  14. Dresa91
    User of the Year 2016; Most Active User 2020 Community Expert Oct 21, 2021
    Dresa91 , Oct 21, 2021 :
    What cable did you use?
  15. P1567672199868
  16. Dresa91
    Can you please try a different one?
  17. P1567672199868
  18. Dresa91
    Did you enable media transfer via notification bar? Did you install all drivers on the pc?
  19. P1567672199868
  20. Dresa91
