charging issue via OnePlus 6
  1. sarath_vavi
    Cupcake Feb 15, 2020
    sarath_vavi , via OnePlus 6 , Feb 15, 2020 :
    My op6 is not charging fast. whenever i charge my mobile it only shows charging with red led. I tried with another socket, another op charger,, still it's mit charging rapidly.. i tried to search theards regarding this, i couldn't find any. any suggestions??
  2. camohan
    Moderator Moderator Feb 15, 2020
    camohan , Feb 15, 2020 :
    Have you tried charging with a different cable?
  3. sarath_vavi
  4. Madnezz4Ever
    Jelly Bean Feb 15, 2020
    Madnezz4Ever , via OnePlus Community App , Feb 15, 2020 :
    Did you try cleaning the charging port on the phone?
    Did you check to see the cable is fully inserted into the phone as it will only slow charge if not. You can try a little pressure to see if it starts to rapid charge.
    There are lots of topics on charging issues on here.
  5. sarath_vavi
    yes i tried putting some pressure,, cleaned the pin too
