Charging Issue
  1. Moosekey07
    Cupcake Feb 27, 2020
    J1577084917511 likes this.
  2. Vertigojnr
    Eclair Feb 27, 2020
    Moosekey07 likes this.
  3. J1577084917511
  4. harshil1903
    Jelly Bean Feb 27, 2020
    harshil1903 , via OnePlus 7T , Feb 27, 2020 :
    I don't see how the device would discharge when connected to a charger unless you've used a external power driven portable hard drive to connect to your device. In that case it sometimes discharge when connected to power supply, although a mere restart resolves the problem.
    The problem might be with your adapter.
    Same goes for you, check your charging adapter and cable to see if there are any cuts or damage of any kind.
  5. Vertigojnr
    Eclair Feb 27, 2020
    Vertigojnr , Feb 27, 2020 :
    I know you want to show off ur knowledge... But this isn't the platform for you dude. Mine Cable is less than 2 Weeks old so is my device and 30 Watt Brick Charger... Never happened until after the last update... It gets even worse when am using the device while plugged in. Once it gets to at some point it begins to discharge... after getting stuck for a while...
    Moosekey07 and J1577084917511 like this.
  6. J1577084917511
    J1577084917511 , via OnePlus 7 , Feb 27, 2020 :
    yes
  7. harshil1903
    No need to get cocky, it won't get you anywhere, all I did was answered regarding the issue.
    There's a reason charging cables are now shorter than before. It's because people would stop using the phone while it is being charged. You didn't stop doing that, which might have resulted into hardware defect.
    xnutzii likes this.
  8. Vertigojnr
    Eclair Feb 27, 2020
    Yeah am sure the defect started after the update though
  9. Liehjan
    Lollipop Feb 27, 2020
    Liehjan , Feb 27, 2020 :
    What, this has to be a joke?:D
    xnutzii, Moosekey07 and harshil1903 like this.
  10. Liehjan
    Report it here https://forums.oneplus.com/feedback/
  11. harshil1903
    Indeed it is. xD
    The primary reason was that they'd sell the longer cables separately for extra money, but they needed to come up with an answer acceptable for people for cutting them short.
    xnutzii and Liehjan like this.
  12. Arun_Kashyap
    Gingerbread Feb 27, 2020
    Arun_Kashyap , via OnePlus 7 , Feb 27, 2020 :
    harshil1903
    There's a reason charging cables are now shorter than before. It's because people would stop using the phone while it is being charged.​
    The true reason cables are short is to deliver more current. A longer wire would mean more resistance thus less current being delivered. Thus wires are designed to be reachable enough but also short at the same time. Also this helps them cut material costs.
  13. xnutzii
    xnutzii , via OnePlus 6T , Feb 27, 2020 :
    You don't understand ironic things too well, do you?
    harshil1903 likes this.
  14. Arun_Kashyap
  15. xnutzii
  16. Arun_Kashyap
    xnutzii
    Obviously nope, otherwise you wouldn't have said "the true reason..."​
    Shared a fact in general, irrespective of the context. Didn't mean to spoil the fun.
  17. xnutzii
    Alright. Next time maybe just don't or mention it being a general thing, thanks.
    harshil1903 and Arun_Kashyap like this.
