charging issue
  1. vashish0412
    Froyo Apr 7, 2020
    vashish0412 , Apr 7, 2020 :
    does anyone else get this problem, when I put my phone to charge every couple of seconds it beeps, like if the rapid charging is coming off and on?
    anyone know what's the problem, I recently bought this phone as well and still have 1 year manufacturer warranty.
  2. Cervantes
    Lollipop Moderator Apr 7, 2020
    Cervantes , Apr 7, 2020 :
    Hi
    there are many threads with this same question
    You checked the usb connector, cleaned it
    vashish0412 likes this.
  3. vashish0412
    Froyo Apr 8, 2020
    vashish0412 , Apr 8, 2020 :
    yes I did same thing happening, I don't know why or what can be done
  4. Secondbushome
    Honeycomb Apr 8, 2020
    Secondbushome , via OnePlus 7 Pro , Apr 8, 2020 :
    Sometimes a dying cable will do that since it isn't able to support a constant flow of power, charging will keep restarting. You can try using another cable and see if the problem persists.
