Charging issue via OnePlus 5T
  1. N1515583399127
    Cupcake Dec 4, 2020
    U1525202767733 likes this.
  2. K1ngP1n
    Ice Cream Sandwich Dec 4, 2020
  3. sk_kunal
    Cupcake Dec 4, 2020
    sk_kunal , via OnePlus 5T , Dec 4, 2020 :
    after connecting charger,on screen is it saying rapidly charging?or only charging?& while charging which color light is on?blue or red?
  4. N1515583399127
    Cupcake Dec 7, 2020
    N1515583399127 , via OnePlus 5T , Dec 7, 2020 :
    It's showing only blue light but not charging symbol and also it's not showing charging or rapidly charging.. if it showing charging by chance after 20min also not even one percent charged
  5. sk_kunal
    Cupcake Dec 7, 2020
    sk_kunal , via OnePlus 5T , Dec 7, 2020 :
    did u update ur device to latest version 10.0.1?if this problem occurred after update then try to factory reset ur device.new update can cause this types of problem.
  6. K1563994298383
    Cupcake Jan 22, 2021 at 2:31 PM
    K1563994298383 , Jan 22, 2021 at 2:31 PM :
    Hey everyone...since last couple of days my OnePlus 5t model is having some issues in charging.. the red light flashes on putting a charger...but there's no charging sign on the right top corner which used to indicate before on plugging a charger...also the charging has reduced drastically and is taking long time for charge..pls help
  7. BeardyBiceps
    Jelly Bean Jan 23, 2021 at 8:43 AM
    BeardyBiceps , via OnePlus 5T Midnight Black , Jan 23, 2021 at 8:43 AM :
    Clean the port also check the same cable with other device
