Charging issue via OnePlus 5T
  1. Z1601632099482
    Cupcake May 13, 2021
    Z1601632099482 , via OnePlus 5T , May 13, 2021 :
    Why fast charhing is not working in my phone? I am not getting the blue light notification and any diplay notification that saying charhing rapidly or charging.
  2. Shailender Sharma
    Marshmallow May 13, 2021
    Shailender Sharma , May 13, 2021 :
    Clean the USB Port
    Charging problems may be caused by debris blocking the physical connections in the charging port. Dirt, dust and lint can get between the metal pins of the charging cable and charging port, preventing electricity from flowing. If this is the case, gently swab the connection port with a toothpick to remove any debris. Be careful not to damage the connector pins.
    KaranRIyer likes this.
  3. Dresa91
    User of the Year 2016; Most Active User 2020 May 13, 2021
    Dresa91 , May 13, 2021 :
    You can also blow into the USB port.
    can you also please check the charger, cable and socket.
    Can you test your charger and cable with another OnePlus phone?
    Can you test another OnePlus charger and cable?
    Shailender Sharma likes this.
  4. Z1601632099482
  5. Dresa91
    Does it work in safe mode?
    you can try to reset your phone (after a backup of your data).
    Maybe it’s a sw thing,…
    ASOk191184 likes this.
  6. ASOk191184
    Cupcake May 14, 2021
