Charging Issue
  1. MamtaModgil
    Cupcake May 19, 2021
    MamtaModgil , May 19, 2021 :
    My one plus 6 is not charging properly. When i plug in the charger it keeps on toggling from rapidly charging to not charging every 2-3 seconds. Light colour keeps on changing from blue to red to blue and so on
  2. Shailender Sharma
    Marshmallow May 19, 2021
    Shailender Sharma , May 19, 2021 :
    Clean the USB Port -
    Charging problems may be caused by debris blocking the physical connections in the charging port. Dirt, dust and lint can get between the metal pins of the charging cable and charging port, preventing electricity from flowing. If this is the case, gently swab the connection port with a toothpick to remove any debris. Be careful not to damage the connector pins.
    rhyd1am likes this.
  3. MamtaModgil
    Thank you for the super fast reply. I cleaned the port, and now it is charging much better.
    Thanks again!!
    Shailender Sharma likes this.
  4. Shailender Sharma
    Glad to be of help. :)
    rhyd1am likes this.
