mahinani , via OnePlus 9 Pro , Oct 17, 2021 : From last few days mobile charge are going down in very less time i dont know ..if i keep 100% charge it will be max of 7-8 hours after that cmng down to 20-30% what was the issue .. disgusting
Dresa91 , Oct 17, 2021 : Hey, can you please clean the USB port carefully? Can you please also check via settings - battery if optimized charging is enabled? If yes, please disable it, restart the device and check again
G_plusone , Oct 17, 2021 : this is usual after an update. update all your apps in google play and charge phone overnight
J4t1np4r3kh , Oct 17, 2021 : If this person is complaining about getting 7-8hour SOT, I'm not sure what their expectations are Probably coming off a Nokia brick 😂😂
mahinani , via OnePlus 9 Pro , Oct 18, 2021 : I did everything still the issue same .. battery drain soo fast ..and stand time max 7-8 hours if i use continuesly
Dresa91 , Oct 18, 2021 : please stick to this thread https://forums.oneplus.com/threads/...heating-and-charging-feedback-thread.1412143/ And take a look at https://forums.oneplus.com/threads/battery-analysis-and-battery-drain-trouble-solving.1413430/, https://forums.oneplus.com/threads/updated-2021-no-more-lags-freezes-battery-drain-heating.1415175/and https://forums.oneplus.com/threads/battery-facts.995140/
A1603314341566 , via OnePlus 9 Pro , Oct 18, 2021 : That is good one compares to my 9 pro device it drains in max 5 to 6 hrs SOT without any gaming. with normal use.
