Charging issue
  1. ayyubph
    Eclair Jan 26, 2015
    ayyubph , Jan 26, 2015 :
    Same issue here
    hemantjaiswal17 likes this.
  2. hemantjaiswal17
    Froyo Jan 26, 2015
    hemantjaiswal17 , Jan 26, 2015 :
    i did that but unfortunately there are no networks because my sim is still 2G. (3G not activated yet) but 3G network is not good of aircel in delhi.
  3. mihirmwd
    Gingerbread Jan 26, 2015
    mihirmwd , Jan 26, 2015 :
    Then your badluck bt yea try with someother sim and try in 3G nly mode n try chrging it
  4. BOOTMGR
    Froyo Jan 26, 2015
    BOOTMGR , Jan 26, 2015 :
    I'm having same issue. In my case its even worse. After receiving 4-5 messages while charging my opo started to wake up automatically (i've enabled wake on disconnect) without any notifications or any other thing.
  5. Naveen P
    Gingerbread Jan 27, 2015
    Naveen P , Jan 27, 2015 :
    I too have that issue I have discussed already in another thread but didn't resolved.donno what to do.:(
  6. Vivek24
    Donut Jan 28, 2015
    Vivek24 , Jan 28, 2015 :
    I too have same issue.
    I think OPO charger/wire is somewhat loose and when there is a SMS my phone vibrates. The movement due to vibration seems to cause the wire to go charging-discharging-charging hence creating the associated alert sounds.
    When i press in the charging wire well enough, the sound seems to stop. I need to try this few more times to be really sure.
  7. yasir. farooqui86
    Eclair Jan 28, 2015
    yasir. farooqui86 , Jan 28, 2015 :
    I too have the same problem , my charger constantly get the disconnect sound and the charger light notification goes on and off every time ., i think we have issue with the socket i have no issue when i charge the phone with another charger nor problem with the OPO cable ,i use the cable with my MI power bank its working perfect , friends do let me know the solution ?
  8. yasir. farooqui86
    Eclair Jan 28, 2015
    I too had the same problem brother
  9. shubham.dhand
    Gingerbread Jan 28, 2015
  10. dr_tushar
    Cupcake Jan 31, 2015
    dr_tushar , Jan 31, 2015 :
    me too having the same problem... will try to return it... i have read in another thread that they dont have stock for charger... they give partial refund... if that is the case then im droping the idea of refund as i hav to travell 250kms for that. OPO is a nice phone but seriously, so many people complaining about the charger, not good for the company.
  11. mihirmwd
    Gingerbread Jan 31, 2015
    mihirmwd , Jan 31, 2015 :
    Did u all tried switching to only 3G mode n thn charging will not drop in between...i had this issue and simply changed my network from 2g to 3g only You can do this from toggles NETWORK MODE toggle n chnge to only 3g....give it a try before replacing your opo
  12. Zahidw
    Eclair Feb 16, 2015
    Zahidw , Feb 16, 2015 :
    i have a similar issue while charging.. and i think its the adaptor, where you able to change the adaptor from the service centre?
  13. suthar.kalpesh57
    Froyo Feb 16, 2015
    suthar.kalpesh57 , Feb 16, 2015 :
    dude even i had the same problem in my previous 3 oneplus one devices yes 3 oneplus one back to back.charger is fine and data cable is also fine.i have done alot of R&D regarding this issue.after i come to knw that the problem is with the phone.when i put the mobile data on and charge my phone it frequently connect and disconnects it self.this is manufacture defect if u can return the phone return it.and buy new one.i bout bought three time and returned it.now i cant buy that phone again.because only 3 phone per account is allowed.:-(
    i hope this will help u :p
    still i'll buy from my friend's account.never settle :)
    Dheeraj.exe likes this.
  14. nhs2
    Cupcake Mar 27, 2015
  15. yasir. farooqui86
    Eclair Mar 27, 2015
    yasir. farooqui86 , Mar 27, 2015 :
    I am also facing the Same issue , the sound is of connecting and disconnecting of charger, i have found its not the hardware issue , because when i change my network mode the problem is resolved , try doing soo it will be helpful
  16. badvishal
    Froyo Mar 27, 2015
    badvishal , Mar 27, 2015 :
    guys i am also facing the issue but by making switching off the mobile data it worked for me.
    try to connect any WiFi and then put mobile on charge
    i hope this will work.
  17. badvishal
    Froyo Mar 27, 2015
  18. nemesi54
    Cupcake May 3, 2015
    nemesi54 , May 3, 2015 :
    I'm having the issue when i charge and receive a message or when i'm in call.
    Changing to 3G Mode Worked for me!!
    Thanks @mihirmwd
    But even this is not a solution.
    I don't want my phone in 3G mode.
    OnePlus Should give a solution....(yea right...)
    #38
  19. mihirmwd
    Gingerbread May 3, 2015
    mihirmwd , May 3, 2015 :
    This issue persist in cm12 also however in cm12 we cnt chnge to 3g nly mode n i am facing the charging bug again :(... Hoping tht cm guys are lstng n doing smthng about it
    #39
  20. nemesi54
    Cupcake May 3, 2015
    #40
