2
charging issue
  1. chikkiepatil
    Donut Mar 25, 2017
    Leventarsenal and luukardinho like this.
  2. kotadheeraj
    Eclair Mar 25, 2017
  3. tulip_bibs
    Honeycomb Mar 25, 2017
  4. Akhil_Murali
    Eclair Mar 25, 2017
    Akhil_Murali , Mar 25, 2017 :
    Even I faced the same issue. The only solution to your problem is to change your cable. OnePlus cables are not so much of a superior quality. Try some third party cables such as mivi or boat. That'll solve your concern.
  5. nikhilanroid7
    Gingerbread Mar 25, 2017
    nikhilanroid7 , Mar 25, 2017 :
    Here's my review:-
    Original cable + original charger = 1600-1800mAh.
    Original cable last long for one year.
    Mivi cable + original charger = 1600-1800mAh.
    Recently bought mivi cable usb type c 3.0
    Original charger + nokia micro usb cable + Oneplus usb type c adapter = 1500-1700mAh.
    Btw My Oneplus2 charge 0-100% within 1.45hr even less if i power off the mobile.
  6. F_Marco_Altea_RUmv
    Cupcake Mar 25, 2017
  7. ranadeepbasani
    Cupcake Mar 26, 2017
    ranadeepbasani , Mar 26, 2017 :
    I am also facing issues guys.. But draining issues are more in this update.. The standby is 10 hrs. Max.. Have tried different charger.. In about 1:30 hrs the battery is full... But now checked the settings and battery mode it's just showing 10 hrs.. Plead help me.. I have cleared the cache.. Still the same issue..
  8. Vikasrajput_94
    Eclair Mar 26, 2017
  9. nikhilboggarapu
  10. Vikasrajput_94
    Eclair Mar 26, 2017
    Vikasrajput_94 , Mar 26, 2017 :
    does mivi cable charge faster than original cable ? coz right now op2 cable takes about 5-6 hr charging to get 100% and if I use my device in btw charging , battery starts to drop instead of charging or remaining same!
    G_Aman_Lahariya_RBLn likes this.
  11. Vikasrajput_94
    Eclair Mar 26, 2017
  12. Nandish Chandrashekar
    Gingerbread Mar 26, 2017
    Nandish Chandrashekar , Mar 26, 2017 :
    wipe cache and data.
    I was also facing the issue but now the battery is great
    (my phone is over an year old)
    watch the screenshot
    Leventarsenal likes this.
  13. Nandish Chandrashekar
    everyone asked me to change the cable, but I knew that the cable is fine.
    So I wiped the cache and data , now it charges within 2 hrs and I get around 15 to 20hrs of usage time..
  14. nikhilanroid7
    nikhilanroid7 , Mar 26, 2017 :
    Yes.. It is fast...0-100% within 2hrs
  15. AkshaySargar
  16. G_Vishnu_B_Krwz
    G_Vishnu_B_Krwz , Mar 26, 2017 :
    It's taking more than 4 hours to charge to 100%.but sometimes when i adjust the cable in charger adapter it is charging under 2 hours. It's because our usb side of charger is reversible the part inside it is moving & it getting faulty fast. Am using my second charger. My first charger got faulty within 6 months and I got it replaced from oneplus. Bt the second one is doing the same, getting faulty within one year. Oneplus quality is not as good as i thought it would be... Very disappointing..
  17. G_vinod_parmar_vntd
  18. ms_ashwin98
  19. Aman_Lahariya
    Aman_Lahariya , Mar 26, 2017 :
    Same thing happens with me sometimes....check screenshot below.
  20. G_Guillaume_Ouellette_Sx
