Charging issues
  1. TheLazyBum
    Froyo Aug 24, 2014
    TheLazyBum , Aug 24, 2014 :
    Hey guys,
    I am experiencing some issues while charging.
    When I charge my OPO, after a while, it just stops charging and i have to unplug and plug the cable again...
    But I can't unplug the charger, I have to unplug it at the device's USB-Port, othwise it doesn't work...
    Anyone else experiencing this?
  2. Hanson Lee
    Marshmallow Aug 24, 2014
  3. itsarave
    Gingerbread Aug 24, 2014
  4. TheLazyBum
    Froyo Aug 24, 2014
  5. Ryan
    KitKat Aug 24, 2014
    Ryan , Aug 24, 2014 :
    The only problem I have with charging is that the cable sticks. I have to use a little more force than I would with any of my other chargers to remove it from my OPO.
  6. erictjf
    KitKat Aug 24, 2014
  7. TheLazyBum
    Froyo Aug 24, 2014
    I think, that's quite nice, got the same, I have to push and pull it really hard.
    So it seems, like a defect, if anyone else heard about something?
  8. itsarave
    itsarave , Aug 24, 2014 :
    Mines quite a tight fit aswel.
    First time I charged it stopped charging but since it has been fine.
    I've read about people having problems when trying different charger combinations.
  9. TheLazyBum
    Froyo Aug 24, 2014
    I am using just the charger, which they sent me...
    The issue appears every time, I charge the phone for a longer time.
    It charges about 50 % and stops then.
  10. pigmeej
    Community Veteran Aug 24, 2014
  11. TheLazyBum
    Froyo Aug 24, 2014
    I got the phone since about 5 weeks... rebooted it several times and 3 updates happened, but didnt fix it.
  12. drmartin
    Moderator Moderator Aug 24, 2014
    drmartin , Aug 24, 2014 :
    Moved to Technical Support.
    And I do not have this issue.
  13. TheLazyBum
    Froyo Aug 24, 2014
  14. Mihail_Ko
    Jelly Bean Aug 24, 2014
    Mihail_Ko , Aug 24, 2014 :
    There allbthose questions about using the original charger, wy is it important I kan charge my one with every charger I have.
  15. thezero
    Cupcake Aug 24, 2014
    thezero , Aug 24, 2014 :
    had that issue once. stuck at 97%. rebooted to recovery cleared cache and it was al ok then.
  16. TheLazyBum
    Froyo Aug 24, 2014
