Charging on 220v - screen freaking out
Thread Status:
Not open for further replies.
  1. AWScreo
    Gingerbread Jan 15, 2016
    AWScreo , Jan 15, 2016 :
    Not sure if anyone reported the bug.
    I'm currently on a holiday trip, and what I just found out is that screen completely freaked out on me when I was charging my phone in airport. Couldn't scroll at all, clicks sometimes worked, but most of time wouldn't react. Also if I was in an app, phone would go into random sections of the app, like it was receiving a click command even if wasn't touching the screen. Trying to restart, didnt work. I guess it has something to do with a higher current in the socket. I mean in US charging makes my screen less responsive and leggy, but at least I could use it.
    Adityaf likes this.
  2. meatandy
    Oreo Jan 15, 2016
    meatandy , Jan 15, 2016 :
    If you indeed tried to charge the phone with 220 volts ,
    You fried the guts of your phone.
    What charger did you use since the outlet for 220v has a different configuration.
    Aceteria likes this.
  3. Tokolozi
    The Lab Reviewer - OPPO Find N Jan 15, 2016
    Tokolozi , Jan 15, 2016 :
    It may be that your charger is faulty and putting a dc offset on the ground, try another one to see if this resloves the issue.
  4. AWScreo
    What do you mean. Look at the charger, it's rated 100-240v like any other phone charger out there. I've been travelling with Android phones for years and never had a problem of frying my phone with 220v outlet.
    Phone works fine, charged to 100%, I just couldn't use it for an hour which I spent watching vids on iPad..
  5. AWScreo
    Mm, I've been charging with it since I bough my phone (3 months I think), never had an issue with it. I can't test another charger right now since I'm on the road.
  6. Manas Eapen
    Jelly Bean Jan 15, 2016
  7. Tokolozi
    Well as soon as you can try it out and see if it still persists, usually the charger should output 5v no matter what, bit the question is how 0-5V or for example 10-15V is also a possibility with a filtercap/coil gone bad.
  8. AWScreo
    I
    ll try as soon as I can. But I'd blame a dodgy socket in shanghai's airport myself ahead of my charger being broken.
    Tokolozi likes this.
  9. Tokolozi
    Yeah that's always an option as well, never know what comes out of those, might as well have been 200dc for all we know.
  10. AWScreo
    Especially in China :)
  11. Deactivated User
    Jan 15, 2016
  12. #HYPEorGTFO
    KitKat Jan 15, 2016
  13. Tokolozi
    Travel adapters
    #HYPEorGTFO likes this.
  14. Deactivated User
    Jan 15, 2016
  15. MafiaTechTeam
    MafiaTechTeam , Jan 15, 2016 :
    When charging my screen becomes less responsive, but meh, I don't use it whilst charging anyway
  16. aj7400
    Ice Cream Sandwich Jan 15, 2016
    aj7400 , Jan 15, 2016 :
    I am in india with 220-240 volts current..
    And my op2 screen also acts unresponsive while charging ...
    I tried to downgrade to 2.1.2 its still the same ...
    I dont know whats causing the issue ,but its still there
  17. vinko1950
    Eclair Jan 15, 2016
    vinko1950 , Jan 15, 2016 :
    I have the same problem with my OP2, screen is less responsive while charging.
    It is happening since I got my OP2, and I got through 2 or 3 updates.
    I don't use it when it's charging, just to send a message or 2 every 20-30 mins and that's when I noticed
  18. eranm5
    eranm5 , Jan 15, 2016 :
    220V is the input. What matters is the output, which is usually between 5 to 5.2 volts. It sounds like a grounding issue.
  19. Dimmerworld
    Honeycomb Jan 15, 2016
    willy156 likes this.
  20. Manas Eapen
    Manas Eapen , Jan 15, 2016 :
    Interesting place to live...
