Charging port replacement cost?
  1. G_Ayush_Dhoot_FnCr
    Gingerbread Apr 2, 2018
    G_Ayush_Dhoot_FnCr , Apr 2, 2018 :
    my phone won't dash charge and it won't be recognized in my pc...
    charging port is dead.
    any estimates on how much it would cost to get replaced?
    Anant8265 likes this.
  2. sohrab250
    Donut Apr 2, 2018
  3. adrianatencia
    Froyo Apr 2, 2018
    adrianatencia , Apr 2, 2018 :
    With the phone turned off, carefully try to clean the port using a needle to remove the fluff inside. Sometimes this method repair the communication problems and the cable connect more strongly.
  4. abhikjain94
  5. rupaksharma007
    Eclair Apr 2, 2018
  6. ghostofcain
    Marshmallow Apr 2, 2018
    ghostofcain , Apr 2, 2018 :
    NEVER clean the charging port with a metal implement, even if turned off its possible to short it out, use a wooden toothpick or something made from plastic.
    Jatin Madaan likes this.
  7. Eustacio Sealy
    Ice Cream Sandwich Apr 2, 2018
    Eustacio Sealy , Apr 2, 2018 :
    Sorry to have to ask this question but you indicated that the phone does not charge when connecting to the computer, does the phone charge when you use the dash charger?
    farhanbadarcher likes this.
  8. Eustacio Sealy
    Every one is providing options but none have asked you if the phone is capable of charging with the default method?
    farhanbadarcher and Keshav69 like this.
  9. Aman Singh gurjar
    Ice Cream Sandwich Apr 3, 2018
    Aman Singh gurjar , Apr 3, 2018 :
    first three words " my phone wont dash charge".
  10. Jatin Madaan
    Cupcake Mar 27, 2019
    Keshav69 likes this.
  11. Tobikage
    Nougat Mar 27, 2019
    ghostofcain likes this.
  12. Bintang12
    Honeycomb Mar 27, 2019
    Bintang12 , Mar 27, 2019 :
    cotton buds?
  13. ghostofcain
    Marshmallow Mar 27, 2019
    ghostofcain , Mar 27, 2019 :
    If you think you can get it in there, and out without dumping any threads.
    Bintang12 likes this.
  14. juanarambula445@
    Cupcake Jul 9, 2019
    juanarambula445@ , Jul 9, 2019 :
    I'm replying in 2019 but I changed this part myself the part was 10 Dollars on eBay and 1 year later the new part works perfectly it's the easiest replacement on a OnePlus 5.
  15. Ashish Chaurasiya
    Eclair Jul 9, 2019
  16. karthik oneplus
    Ice Cream Sandwich Jul 10, 2019
    karthik oneplus , Jul 10, 2019 :
    I think to change charging port they might ask to replace motherboard. Charging port are soldered. Not sure how it is for oneplus phones.
  17. rohitbhardwaj
    Cupcake Oct 16, 2019
  18. Madnezz4Ever
    Jelly Bean Oct 16, 2019
    Madnezz4Ever , Oct 16, 2019 :
    Since the topic is already bumped up.
    Unless they use a different port on the 3 then the 5T, no the charging port is not soldered on and is actually a ribbon cable that also connects to the headphones jack. At least, that's how it is on the 5T and is easily changeable once the screen is off.
