28
Charging Problem & its Solution
Did it work for you?
  1. Yes
    43.8%
  2. No
    56.3%
  1. G_Ajay_Singh_PZlC
    Cupcake Dec 28, 2016
    G_Ajay_Singh_PZlC , Dec 28, 2016 :
    1) go to play store and download shortcut master (LITE)
    2) OPEN it then search for "band" there will be 3 options you have to go for engineermode 1 and 2
    3) select no 1 click launch
    4) now select combination of wdma850/1900
    5) do gsm850/1900 with 2nd one and u r done.
    I don't think that this problem will be fully solved but network drop will stop and battery drain will decrease
    Hope so, it will also work for u
    #81
  2. Vikram Anand Jaipur
    Vikram Anand Jaipur , Dec 28, 2016 :
    This is with what combination - I mean Jio sim in slot one & other 2G sim in slot 2? In case these are installed opposite, should the solution also be done opposite?
    #82
  3. G_Bhavya_Shah_CFIN
    #83
  4. Zh_kilat
    Android Q Dec 28, 2016
    Zh_kilat , Dec 28, 2016 :
    Congrats......
    #84
  5. G_Ajay_Singh_PZlC
    If ur using Jio sim then select wdma 850/1900 combination for engg mod 1 and select gsm850/1900 for second.....most of u are using Jio sim
    #85
  6. G_Ajay_Singh_PZlC
    it's bcuz network drop.......follow my steps ur network drop problem will be solved and battery drain will stop
    #86
  7. saikiran4ever
    Jelly Bean Dec 28, 2016
    saikiran4ever , Dec 28, 2016 :
    A few questions here:
    - When you restart the mobile, do these changes persist?
    - When you select "WCDMA850/1900", you are mostly restricting your mobile to receive only 850/1900 band. In India, Reliance JIO has 3 bands: 850, 1800 & 2300 where 850 has better coverage. As JIO is in trial phase, it has restricted the speed throughput of 850 band to less number comparatively. Are you OK with that?
    - Are you sure that GSM850/1900 will work for all 2G networks ? Signal may be lost if network providers do not supprt 850/1900 bands for GSM.
    I think, this is a great solution for now. But, it's better to wait for a permanent fix for the issue. I heard that Oneplus is going to release the fix in a day or so...
    Source: https://forums.oneplus.net/threads/oxygenos-3-5-5-mm-ota-for-oneplus-2.480546/page-137#post-15517327
    #87
    nageshchandana likes this.
  8. Varnai _Sharma
    #88
  9. G_nithan_biddappa_BOdE
    Donut Dec 28, 2016
    #89
  10. Vikram Anand Jaipur
    I lost both of my networks by doing so. How to revert ......
    #90
  11. VENKAT11214
    Froyo Dec 28, 2016
    #91
  12. G_Ajay_Singh_PZlC
    #92
  13. G_Ajay_Singh_PZlC
    Restart ur phone
    #93
  14. G_Ajay_Singh_PZlC
    Jio is working on wdma 850-1900 band...its works
    #94
  15. Vikram Anand Jaipur
    #95
  16. pratikagarwal. 2
    Eclair Dec 28, 2016
    #96
  17. Veer1080
  18. saikiran4ever
    Skip Step #5 in the first post. You do not need to do it for Airtel (Sim2/Non-data sim)
    If you have already done it, just restart the mobile. All bands should reset themselves as far as I know.
    #98
  19. tusar8
    tusar8 , Dec 28, 2016 :
    Then your cable is toasted. Buy a new one. I would recommend dash charge cable.
    #99
  20. tusar8
    Download Ampere app from play store. Open app and connect to wall charger.
