3
Charging Problem (OnePlus 6)
  1. maniksingh10
    Froyo May 24, 2018
    maniksingh10 , May 24, 2018 :
    I am facing charging problem on OnePlus 6 when i connect the Dash charger it shows "Charging Slowing" and after some reconnects it shows "Charging Rapidly". Does not charges straight away in one attempt.
    Is this normal or is there a problem?
    Tmigoo, Sagar22263266 and ashwin6004 like this.
  2. Bollux
    Gingerbread May 24, 2018
    Bollux , May 24, 2018 :
    Hi there.
    Got mine half an hour ago, as soon as i put mine charging ill give you my feedback.
  3. maniksingh10
    Froyo May 24, 2018
    Thanks for replying will wait
  4. Bollux
    Check this thread mate, people are talking about it.
    [MEGA THREAD] OP6 Battery/Heating Issues and Tips: Share Your Stats & How To Improve Battery Life !
  5. BobbyV8_
    The Showcase Reviewer May 24, 2018
    BobbyV8_ , May 24, 2018 :
    Can you post a video? Usually Dash charge takes a second or two to get activated. If it changes to charging rapidly under 2 secs, it is normal. If it's taking little longer, the issue might be with the power socket / USB cable / even the charger.
    Try using a different port first.
    N1527272296469 likes this.
  6. ashwin6004
    Honeycomb May 24, 2018
    ashwin6004 , May 24, 2018 :
    It works randomly, its not the issue with adapter or brick. The same brick is working fine with my OP3. I too have the same issue, so most probably this is a software issue. Either oneplus have made a delay for stabilizing voltage or something like that, anyway we need a confirmation on this.
    OPOBEAST and rahuldw181 like this.
  7. BobbyV8_
    @RJBoss can you comment on this?
  8. BobbyV8_
    We have 2 more here.
    @Gary C. any official statement on this?
    NeVeR_SeTTLe likes this.
  9. arun_arora
    Cupcake May 24, 2018
    arun_arora , May 24, 2018 :
    Did not see this issue with my OP6. I see Bolt Icon immediately afrer connecting charger.
    Recharge cycle: 3rd
    software version: A6000_22_180517
    Region: India
  10. arun_arora
  11. rahuldw181
    Ice Cream Sandwich May 24, 2018
    rahuldw181 , May 24, 2018 :
    I am also facing it. it's a software bug
  12. rahuldw181
    I am facing it. it takes 2 minutes to enter charging rapidly mode
  13. arun_arora
  14. ashwin6004
    so it is a common issue, thank god, i was really scared [e]1f601[/e][e]1f601[/e][e]1f601[/e]
  15. RJBoss
    RJBoss , May 24, 2018 :
    Didn't test the charger that came with the OP6 box as I still got the 5T's charger working fine as well for me. And no, No such problems faced.
    To the OP,
    If it doesn't reaches 95-98% from 2-5% within 90 minutes, only THEN get it replaced.
  16. Bollux
    I connect the charger and dash instantly fires up
    Sorry for the delay my friend.
  17. tWoBrO
    tWoBrO , May 24, 2018 :
    Just tested with my OP6 and it works fine. Connected and in two seconds was fast charging.
    Tried with the charger that came with the phone and one from OP5. Both fine.
    meatandy likes this.
  18. maniksingh10
    Froyo May 25, 2018
  19. BobbyV8_
    The Showcase Reviewer May 25, 2018
    BobbyV8_ , May 25, 2018 :
    How can you say it's a software bug? Why can't it be hardware?
    That's great, can you test it out once? Just for confirmation. It should be fine though.
    RJBoss likes this.
  20. meatandy
    Oreo May 25, 2018
    meatandy , May 25, 2018 :
    Do you have another oneplus brick to try charging from?
    It should go into rapid charging with in seconds.
