3
Charging Problem (OnePlus 6)
  1. maniksingh10
    Froyo May 25, 2018
    maniksingh10 , May 25, 2018 :
    No I don't have one. But sometimes it connects on first attempt
  2. maniksingh10
    Froyo May 25, 2018
  3. meatandy
    Oreo May 25, 2018
    meatandy , May 25, 2018 :
    My battery is full now , I'll have to look tomorrow.
  4. RJBoss
    The Showcase Reviewer May 25, 2018
    RJBoss , May 25, 2018 :
    I didn't face any problem when I charged my OnePlus 6 from 5% to 90% in 1 hour time! It always showed DASH icon!
    BobbyV8_ likes this.
  5. vnaveensai
    Cupcake May 25, 2018
    vnaveensai , May 25, 2018 :
    its taking time for me as well about 25 sconds, but the bolt icon was showing within 2 seconds. Is it normal to every one .?
  6. Claudio puglielli
    Donut May 25, 2018
    Claudio puglielli , May 25, 2018 :
    me too
  7. A1527261852153
  8. Boss_18
    Froyo May 25, 2018
  9. RJBoss
    Did you root it?
  10. A1527261852153
  11. RJBoss
  12. Kiran_kittu
    Froyo May 25, 2018
  13. X1527271512209
    X1527271512209 , May 25, 2018 :
    Guys could you inbox me a link which would take me through the complete workthrough of the one plus 6 camera including portrait mode and allied stuffs
  14. guruputtu
    Cupcake Mar 4, 2019
    guruputtu , Mar 4, 2019 :
    Did the problem solved????
  15. dipak0112
    Cupcake Jun 6, 2019
    dipak0112 , Jun 6, 2019 :
    Facing this same issue. Have latest software updates. Phone is changing from slow to rapid mode continuously. 10-12 times in 30 minutes period.have changed power socket, using original charger. Can't figure out the problem. Please help..
  16. Kytharsis
    Marshmallow Jun 6, 2019
    Kytharsis , Jun 6, 2019 :
    Have you tried cleaning out the charging port?
  17. O1565014096191
    Cupcake Aug 5, 2019
    O1565014096191 , Aug 5, 2019 :
    I am having same issue..i have oneplus 6, 6T and 7..recently i have problem with my op6 charging..i checked everything..like dust, trying with different official charger..but nothing worked..it is charging very slow with red led instead of blue. It took 10-11 hours to fully charge it. So finally i took it to op service center..they checked my phone for around 1 hour and finally told me to change mother board which will cost around 21 k..they told me that voltage is not passing from my charging port to mother board..and they also said that this case is rare but they cannot repair the same..I took a decision to buy new mobile and came home..but after two day..i tried again to charge it and it charged rapidly ( dash)..but again after two days same problem came..so i am confused..that if it an hardware issue then how come it charge rapidly sometimes..i guess the engineer at service center and not properly trained...can anyone have any solution or view on this...???
  18. O1565014096191
    Cupcake Aug 5, 2019
    If you have done every trick and still problem is not solved then do below mentioned things-
    1.Try charging in some cafe of somebody else house which is not in same locality.
    2. Check for voltage fluctuations at your home.
    3. Press and hold power button for 20 sec..
    4. If still nothing works then there is a problem with your motherboard..as told by official OP service guys..that due to voltage fluctuations there can be a problem with a bridge circuit on motherboard which is responsible to pass voltage from charging port to motherboard..and new motherboard will cost you a new mobile phone..
    #38
  19. O1565014096191
    Cupcake Aug 5, 2019
    #39
  20. Sebastiaan_Kok
    Cupcake Sep 10, 2019
    Sebastiaan_Kok , Sep 10, 2019 :
    Hello,
    Shame that this Thread is no longer alive. Had the same issue for over 2 months now. Same powersocket, same brick (original) every night. One night it charges after 1-2 tries. Other night it takes me 5 minutes to get it to charge.
    Sometimes slow, sometimes fast.
    Couldn't care less about the speed its charging at, as long as I get to 100% overnight.
    Any new ideas?
    #40
