Charging Problem via OnePlus 6 Midnight Black
  1. WaseemAkram613 , via OnePlus 6 Midnight Black , May 9, 2021 :
    I have one plus 6 mobile. I did last update on 28 March after this there is a problem in Chrginng of my mobile. Mobile battery does not exceed above 80% when i unplugged the cable then again plugged it (Minimum 3, 4 Times) then the Chrginng exceed above 80% kindly help me to resolve this problem
    Please Help Me...
    Thanks In Advance 🙂
  2. Caomhin
    OnePlus 9 Series Expert Community Expert May 9, 2021
    Caomhin , via OnePlus 9 Pro , May 9, 2021 :
    FOLLOW THE STEPS BELOW TO THE LETTER CAREFULLY.
    Some say this can also help, some others state it doesn't.
    Wipe cache partition
    Turn off your device.
    Press and hold the Volume down and Power button at the same time.
    When the OnePlus logo appears, release the Power button, but continue holding the Volume down button.
    At the Password screen, enter the Password or PIN number that you use to unlock your device. When done, tap Ok.
    Tap English.
    Tap Wipe data and cache.
    Tap Wipe cache.
    Tap Yes to continue.
    Tap Reboot to restart the phone.
