Charging problem via OnePlus 9 Pro
  1. Jayanta Maity
    Donut Jul 15, 2021
    Jayanta Maity , via OnePlus 9 Pro , Jul 15, 2021 :
    Yesterday, i have left 10% battery on my 9 pro. Then i plugin and within 15 minutes its charged up 50% .
    That's mean i got 60% (10+50%) battery in just 15 minutes & i thought that 40% will be charged lesser than 15 minutes, but it takes more than 23 minutes. Thats means my 9 pro takes 38 minutes to charged 90% battery. It is good or there is any problem on my phone or charger?? I have always on optimised chargeing.
    sorry for my bad english. 🙏
  2. J4t1np4r3kh
    OnePlus Accessory Tester Jul 16, 2021
    J4t1np4r3kh , Jul 16, 2021 :
    The latter percentages of your phone will definitely take longer than the middle section, so it sounds about right.
    Seems normal to me.
    You can always turn optimised charging off and see if that helps (as optimised charging tries to get your phone charged as and how you 'normally' need it)
    Caomhin, Aaron2017 and Jayanta Maity like this.
  3. Swejuggalo
    OnePlus 9 Series Expert Community Expert Jul 16, 2021
    Caomhin and Jayanta Maity like this.
  4. abdelrahman
    Cupcake Sep 18, 2021
    abdelrahman , via OnePlus 9 , Sep 18, 2021 :
    You speack only about the fukin temperature i living in holland my one plus 9 its top but he charging in 55 fukin munite i did every think to fix that but one plus doesnt care about us so **** one plus company
  5. Swejuggalo
    OnePlus 9 Series Expert Community Expert Sep 18, 2021
    Swejuggalo , via OnePlus 9 Pro Morning Mist , Sep 18, 2021 :
    Well... Heat, background drain, cable issue, screen on or off, charger glitching... Or even software glitch. Heat is just one of the possible factors. And since many has it I start with heat s a factor. You don't really need a hot weather if the device itself runs hot.
    Personally.... 39...59 min or whatever... I usually charge nightly. And those times when I charge anything during the day it's so fast that I often change way more than really need to avoid too low level before bed.
  6. abdelrahman
    jaeboy22 likes this.
  7. abdelrahman
  8. Swejuggalo
    8T has Warp 65 too. That would be a great test to see if the cord or the charger has anything to do with your charge issue.
    Warp 65T uses the same charger.
  9. abdelrahman
    I sended to you private message please answer and help me
