Charging Problem
Do you face similar issue?
  1. YES
    24 vote(s)
    82.8%
  2. NO
    5 vote(s)
    17.2%
  1. chaitu245
    Froyo Jan 26, 2015
    chaitu245 , Jan 26, 2015 :
    Ok now to be precise.... I found out this weird charging issue the other day. When I charge my phone with the mobile data ON in 2G or in 4G mode, the charging keeps fluctuating (ON and OFF). If I do the same in 3G, it works perfectly fine. Does anyone else face the same issue? Do let me know if you can find any solutions on this.
    abhishekezio likes this.
  2. himanshubisht08
    Gingerbread Jan 26, 2015
  3. chaitu245
    Froyo Jan 26, 2015
  4. chaitu245
    Froyo Jan 26, 2015
    Udarji likes this.
  5. SISRO
    Eclair Jan 26, 2015
    SISRO , Jan 26, 2015 :
    have the same issue... not sure if it has anything to do with the network i am using LTE as recommended.
  6. rinkeshg
    Froyo Jan 26, 2015
    rinkeshg , Jan 26, 2015 :
    I faced same with docomo... I think its the problem with the cablr....btw I returned the phone. ...
  7. himanshubisht08
    himanshubisht08 , Jan 26, 2015 :
    no problem with the cable, you opo charger will charge other phone, and other phone charger charges the opo, but opo charger not charging opo properly :D:mad::confused:
  8. himanshubisht08
    its a software issue i guess no hardware
  9. himanshubisht08
    n
    i think with network or with software of opo
  10. chaitu245
    Froyo Jan 26, 2015
    Y did you return the phone?
  11. chaitu245
    Froyo Jan 26, 2015
    If it were a problem with the cable then it shouldnt charge the mobile at all..... But the charge fluctuates only in specific conditions...When my mobile data is ON in 4G or in 2G
  12. rinkeshg
    Froyo Jan 26, 2015
    It ws unbearable with the new phone wrth rs 22k......now I dnt trust this oneplus. ...as service centers are also not responsive.....will wait till oneplus 2 or any other brand....bt I miss my opo......no other phone is as smart as opo...
  13. rinkeshg
    Froyo Jan 26, 2015
    I have jst 2g in my city.....and bcoz of this charging issue only I returned it.....
  14. chaitu245
    Froyo Jan 26, 2015
    Oh....okayy
    I just hope this problem will get resolved once there is an update over it
  15. rinkeshg
    Froyo Jan 26, 2015
    Hmmm they have miles to go ahead.....
  16. hemantjaiswal17
    Froyo Jan 26, 2015
    hemantjaiswal17 , Jan 26, 2015 :
    mate i also have the same problem this problem can be fixed in 2 ways.
    first. use your mobile on 3G network
    second use another charger (USB cable is fine) while charging basically OPO charging adapter is having some problem. I am sure you wont get such problem with another charger.
    BTW your OPO is fine so you don't need to replace it.
  17. chaitu245
    Froyo Jan 26, 2015
    @hemantjaiswal17 .... Yeah I know this can be avoided.... but it certainly is not rectified.... The bug still persists.... So just wanted to know if any update can fix this issue.
  18. hemantjaiswal17
    Froyo Jan 26, 2015
    I am also having the same problem and expecting that this will be fixed in new OPO update.
    but currently i had switched off my that charging sound off it really irritates me.
  19. divsh008
    Cupcake Mar 9, 2015
    divsh008 , Mar 9, 2015 :
    I face somewhat similar issue, but my phone charging keeps on fluctuating when i keep the charging wire in a slanting position. whenever i charge the phone keeping my charger and phone at same level it works fine but whenever my charger is at a height and the phone is charging on a lower suface keeping the wire slant there is charging on and off problem. My phone is jusy 3 days old. service center people say that we need to submit the phone and they would check the problem. I am a lil skeptical giving my phone there. Should i replace it on amazon?????? kindly help :(
  20. sandeepkyadav
    Froyo Mar 9, 2015
    sandeepkyadav , Mar 9, 2015 :
    Hi All, Even I am facing same problem and tried charging it with Galaxy S4 - 2 Amp charger and it worked perfectly. But not sure of charging with another charger for long. I hope it get solved in next update. :)
