Charging problem
  1. G_Samridhi_Jindal_eZHy
    Cupcake Sep 24, 2017
    G_Samridhi_Jindal_eZHy , Sep 24, 2017 :
    Hi everyone,
    I am Samridhi Jindal. I am facing a problem related to charging my phone.
    My phone doesn't charge quickly. I have to keep it charging for the whole day for 80% too and it looses its battery within 1-2 hrs even if it is not in use.
    Please help.
    Regards,
    Samridhi Jindal
  2. DrAakash
    Jelly Bean Sep 24, 2017
    DrAakash , Sep 24, 2017 :
    Your battery could be going dead. Also try using a different charger and cable.
    F_Tuhin_Saha_NVnH likes this.
  3. Deepeshdhonde@1
  4. jokerpappu
    Froyo Sep 24, 2017
    jokerpappu , Sep 24, 2017 :
    go to customer care centre and let them have a look at your device. its the easiest way
  5. G_Gyan_Droid_TUme
    Honeycomb Sep 24, 2017
  6. suhasshendge
    suhasshendge , Sep 24, 2017 :
    I faced similar problem with my device. tried replacing charger with the new one and it worked. make sure you have original charger with you.
  7. suhasshendge
    more importantly it was with OnePlus 2 only. also you can check charging details using ampere app on google play store. and it should be between 1000 to 1500ma speed less than this will cause similar kind of issue and thia indicate problem with your charger....
  8. Jackson george
    Froyo Sep 25, 2017
  9. HarshRanjan23
    Cupcake Sep 25, 2017
  10. remedy
    KitKat Sep 25, 2017
  11. rayu_bleedblue
    Cupcake Sep 26, 2017
    rayu_bleedblue , Sep 26, 2017 :
    I had the same issue and my phone was in warranty. Visited service center and checked. They put up my phone on charging. Opened phone dialer and followed this steps. Dial "*#808#" then choose charger by scrolling down. Then check if the current is between 1500-1900mA. If less than the 1500mA, then the USB cable is not working properly. If the current is between that range then there is a software problem. So they will flash the phone with OOS 3.6.0 and then check again. My phone is now working properly. No battery drain, no slow charging, no overheating.
