charging problem
  1. mbabcy Eclair Jun 13, 2018
    mbabcy, Jun 13, 2018 :
    my op5 doesn't charge, unless I restart the phone. even that it takes a while for dash charge to kick in. any help
  2. the_o2 KitKat Jun 13, 2018
    the_o2, Jun 13, 2018 :
    Clear the charging port both of charger and mobile port with soft dry toothbrush..
  3. AditiRao4 Cupcake Jun 13, 2018
    AditiRao4, Jun 13, 2018 :
    I have the same problem.. that also it charges only when the battery is under 10% and I restart it..
    did you find a solution to this?
  4. the_o2 KitKat Jun 14, 2018
    the_o2, Jun 14, 2018 :
    Try this
    1. Turn the phone off(unplug the charger if charging).
    2. Hold Power and Volume Down
    3. English (or pick any language that you want)
    4. Wipe data & cache
    5. Wipe cache (it's doesn't delete your personal data)
    6. Yes
    7. Reboot.
