Charging problem
  1. iamafreak
    Honeycomb Aug 17, 2014
    iamafreak , Aug 17, 2014 :
    Charging from 95% to 100% takes forever. In fact it was stuck at 99% for couple of hours atleast and i just unplugged. Anyone else facing this problem or is this a know issue?
  2. Hanson Lee
    Marshmallow Aug 17, 2014
  3. iamafreak
  4. jmpxupi
    Froyo Aug 28, 2014
    jmpxupi , Aug 28, 2014 :
    The same happened to me.
    Stuck in 98%.
    Ho do i do a hard reset?
    Does it solve the problem?
    I've noticed a huge battery drain these last week and i'm still with cm25r. (Now in less than 1 day i hsve to charge it. Before that it took 2 days)
  5. jmpxupi
    Froyo Aug 29, 2014
    jmpxupi , Aug 29, 2014 :
    Another day with battery charging and behaviour problems.
    I woke up and i found the battery stuck at 92% after the whole night plugged in.
    And the draining of the battery is huge.
    I need help to solve it.
    One of my thoughts is that after installing the battery monitor widget app something happened with the battery, but i removed the app and it keeps working bad
  6. jmpxupi
    Froyo Aug 31, 2014
    SRRRKSR likes this.
  7. Aaahh
    Marshmallow Aug 31, 2014
    Aaahh , Aug 31, 2014 :
    Keep it in the charger for 24 hours or intill your phone explodes (im serious)
  8. vmk2310
    Jelly Bean Aug 31, 2014
    Aaahh likes this.
  9. jmpxupi
    Froyo Aug 31, 2014
    jmpxupi , Aug 31, 2014 :
    Its the original and i dont have any other.
    Ill buy a new one to check if it works better
  10. narceoneplus
    Honeycomb Aug 31, 2014
  11. chongswee
  12. PeGys
    Gingerbread Aug 31, 2014
    PeGys , Aug 31, 2014 :
    Had the same problem once when charging while it was powered on. Then I drained the battery and charged it while it was powered off. Never happend again.... Even while powered on it charges to 100% now.
  13. Iuzzolsa23
    Eclair Aug 31, 2014
    Iuzzolsa23 , Aug 31, 2014 :
    Was it your first time charging the device?
    I had the same "problem" with mine. It takes two to three charging cycles for the battery to know where 100% are, so don't worry ;)
  14. Haymond
    Ice Cream Sandwich Aug 31, 2014
    Haymond , Aug 31, 2014 :
    good tip, I'll have to keep this in mind
  15. jmpxupi
    Froyo Aug 31, 2014
    Two days not arriving 100% of charge. (98% and 92%)
    I let the phone turn off with no battery and It charged then to 100%.
    Today i charged it again arriving only to 97%.
    I think my battery is doing weird things
    I might open an RMA
  16. radam
    radam , Aug 31, 2014 :
    DONT PANIC! Its actually better for your battery if its not getting 100% charge all the time.
  17. Mrkasser
    Cupcake Sep 1, 2014
    Mrkasser , Sep 1, 2014 :
    i just noticed this happening to my phone over the last couple days too
  18. jmpxupi
    Froyo Sep 1, 2014
    jmpxupi , Sep 1, 2014 :
    today i've used a samsung cable and it charged 100%.
    Since today I am also using battery monitor widget app and the battery drainage is being pretty good: from 8mA to 60mA the last few hours (3 minutes recording) [Receiving some calls, watsapp, and standby]
  19. caffeine
    Ice Cream Sandwich Sep 1, 2014
    caffeine , Sep 1, 2014 :
    You know that 100% is a lie, right? There is no such thing as 100% charge, the upper 5 % are pure approximation.
  20. keithnyc
    Moderator Moderator Oct 7, 2014
