3
Charging sound repeats via OnePlus 7T
  1. Amandeep_8129
    Froyo Apr 11, 2021
    Amandeep_8129 , via OnePlus 7T , Apr 11, 2021 :
    Whenever I plug my phone to battery the default animation of dash charging with sound comes... This is ok. But while using the phone (in charging) I hear the same charging sound which I heard while plugging in my phone.
    Device - op7t
    Os - Oxygen os
    Occurence - 100% of time (always)
    (Whenever I submit in feedback section app either lags or keep crashing and restarting ... So PLEASE FIX THIS ISSUE...
    My BIG MISTAKE TO BUY ONEPLUS DEVICE.
  2. Tokolozi
    Most Original Avatar Apr 11, 2021
    Tokolozi , Apr 11, 2021 :
    Have you tried a different cable, it could be that the cable keeps connecting and disconnecting due to a bad connection (maybe caused by dirt)
  3. Gohil_Chirag
    Gingerbread Apr 11, 2021
    ArthurPopov and Amandeep_8129 like this.
  4. ArthurPopov
    Froyo Apr 11, 2021
    Amandeep_8129 likes this.
  5. N1610396198815
    Eclair Apr 11, 2021
  6. Gohil_Chirag
    Gingerbread Apr 12, 2021
  7. Tokolozi
    Most Original Avatar Apr 12, 2021
  8. Bobbie63
    Marshmallow Apr 12, 2021
    Bobbie63 , Apr 12, 2021 :
    Isn’t that asking what you already know?:rolleyes:
  9. McJader
    Lollipop Apr 12, 2021
    McJader , Apr 12, 2021 :
    This is the reason most of the times.
    But of course others will post "I have this issue too. Hope developers solve" instead of trying a different, cable, charging socket, etc.
  10. Tokolozi
    Tokolozi , Apr 12, 2021 :
    "Let's see bees can be fly on them face or not!"
  11. McJader
    Bobbie63 and Tokolozi like this.
  12. Sheppards
    Jelly Bean Apr 12, 2021
    Sheppards , via OnePlus 7T , Apr 12, 2021 :
    Ah, OnePlus users
    They only want to let others know that they have the same problem, and also if someone else has it
    Additionally they expect broken screens and dirty charge ports to be fixed by software updates
    Bobbie63, Tokolozi and McJader like this.
  13. Tokolozi
  14. Sandeep Poddar
    Ice Cream Sandwich Apr 12, 2021
    Sandeep Poddar , via OnePlus 7T , Apr 12, 2021 :
    If multiple people are reporting it doesn't it proves that the issue exists? Moving from one android update to other means the cable is the one causing issue? Sometimes I guess sarcasm isn't the answer to everything. People facing issues might be genuine. But I see off late that instead of guiding people on the forum, sarcasm is used more often. Which ultimately nullifies the meaning of user forum in first place.
    ArthurPopov and Eslam.Elsagher like this.
  15. Sandeep Poddar
    I did.. I have another op 7t and used its cable.. it happened again. It just makes u wonder that if the cable is losing connection or wasn't put in correctly at the first instance.
  16. itsakash
    Froyo Apr 12, 2021
  17. Tokolozi
    It could also be dirt in your phone connector itself, check with a light to see if you see any dust/lint.
  18. Sheppards
    Again, this ta 99% caused by
    - dust
    - pocket lint
    And last but not least: corrosion.
    If you live in a humid or not so humid, but hot climate (e.g. India), where you can get sweaty and the port can get corroded
    There are videos and products that can help you
  19. Javvadibabajee
  20. Sheppards
