Charging Speed.
  1. Swejuggalo
    OnePlus 9 Series Expert Community Expert Apr 11, 2021
    Swejuggalo , via OnePlus 9 Pro Stellar Black , Apr 11, 2021 :
    What temperatures do you get when charging? What is the battery temp before even starting to charge? Some get a longer charge simply due to their battery is hotter. The charge current gets lowered in such cases.
    #41
  2. OAJJAIN
    Eclair Apr 11, 2021
    OAJJAIN , via OnePlus 9 Pro , Apr 11, 2021 :
    It's below 40 in all cases. I will check once
    #42
  3. Swejuggalo
    #43
  4. OAJJAIN
    Eclair Apr 11, 2021
    Probably due to OnePlus heating bug. Any idea when will a fix will come for it?
    #44
  5. Swejuggalo
    Well. All batteries has optimal ranges, max/min temperature and different speed levels based on temperature.
    Here it is the same battery type as previous phones but just split into 2 cells. So same temperature ranges exist to maintain a safe charge and a long battery life.
    #45
  6. Swejuggalo
    #46
  7. Paget96
    Donut Apr 14, 2021
    Paget96 , Apr 14, 2021 :
    If there is any rooted user, please provide me a screenshot of output:
    su
    dumpsys battery
    Want to check what all info is there.
    Thanks
    #47
  8. CS1989
    Honeycomb Apr 16, 2021
    CS1989 , Apr 16, 2021 :
    How about telegram ? Easier to send
    #48
  9. Paget96
    Donut Apr 16, 2021
    #49
  10. Paget96
    Donut Apr 29, 2021
    Paget96 , Apr 29, 2021 :
    Hello people, I need testers from here in order to test new stuff. My laptop is finally here, so now it's time to work at full.
    BatteryGuru v1.8.9.6-beta3:
    - Fixed issue with showing double current (mA) on dual battery devices
    - Added charging voltage info
    - Updated Watt info (need testing)
    - Updated dependencies
    I need screenshots of the charging section, I want to see charging voltage and wattage also.
    Info I'll also need:
    - Device name
    - Charger type (voltages, wattage)
    - If rooted!!! Need this
    su
    dumpsys battery
    - Is device dual battery one or no
    This is a link to get beta3:
    https://t.me/Paget96_Projects/34595
    This is some non-official way of getting those parameters, so we need to see whether it work or no, so I can decide what to do, what our next steps and so on.
    Waiting to see the results.
    If you want to join the group and have some fast conversation, join telegram
    https://t.me/Paget96_projects
    Thanks for support
    EDIT:
    Beta 5 is up
    https://t.me/paget96_projects_channel/1537
    #50
  11. Paget96
    Donut Apr 30, 2021
    Paget96 , Apr 30, 2021 :
    Battery Guru v1.8.9.6
    ⚡️Download (https://play.google.com/store/apps/details?id=com.paget96.batteryguru)
    ⚡️XDA Thread (https://forum.xda-developers.com/an...atteryguru-t3980767/post80484651#post80484651)
    ⚡️Facebook (https://www.facebook.com/BatteryGuru)
    ⚡️Telegram group (https://t.me/Paget96_Projects)
    ❗️The update will be visible in a few hours when Google does a review. Thanks for using Battery Guru, please share
    ⚙️Changelog:
    - Updated getting app info
    - Improved getting Watt when charging
    - Removed designed toast with default one
    - Updated UI for better organization
    - Removed apps dialog
    - Removed subscriptions from other section
    - Added in app update
    - Added temperature card
    - Added icons to card titles
    - Updated translations
    Improve translation of the app
    https://localazy.com/p/batteryguru
    Donate: PayPal (http://paypal.me/Paget96)
    All apps: PlayStore (https://play.google.com/store/apps/dev?id=6924549437581780390&hl=en)
    #51
