Charging speed!!!
  1. Harish kiddy
    Gingerbread Dec 4, 2017
    Harish kiddy , Dec 4, 2017 :
    After Android 8.0(Oreo) update my one plus 3t takes more time to charging it takes 1.55 hrs (115 minutes) normally it takes only 1hour 20 minutes now it taking longer and battery is only standing for 5.30 hours without 4G or wifi and i switched off gps also..After the update i have done hard reset and i freshly installed all apps.....I want to know is my battery is fault or Os software issue...?
  2. Tasrif Khondaker
    Donut Dec 4, 2017
  3. Shivalik Naik
    V1512465434354 and cmitchellshaw like this.
  4. Mohd_Tausif
    Eclair Dec 4, 2017
    Mohd_Tausif , Dec 4, 2017 :
    the Android 8.0(Oreo) update had some problem (battery issues being one of them) due to which it has been rolled back. Probably its a software problem. Just hold on for some time maybe it will get resolved in the next update. Meanwhile try clearing the phone cache from the recovery mode. Most of the minor problems are resolved after that
    cmitchellshaw likes this.
