Charging time is more via OnePlus 9 Pro
  1. KirankReddy
    Eclair Jul 25, 2021
    KirankReddy , via OnePlus 9 Pro , Jul 25, 2021 :
    Hello,
    I have got the one plus 9 pro on the first day of sale and it was performing good since...
    I have just two concerns with the 9 pro.
    1. Charging time is more for the mobile I'm pocessing...
    2. Discharging is quick..I hardly get 3 to 4 hrs of screen on time.
    When I checked with the my friend who got one plue 9 pro..she didn't have both the problems..her phone gets charged within 28 mins and gives around 6 to 7 hrs of screen on time.
    Can anyone help me on this if you are also facing the same issue??
    G_plusone likes this.
  2. G_plusone
    Nougat Jul 25, 2021
    Best Answer
    G_plusone , Jul 25, 2021 :
    Are both the phones on the same software version?
    You and your friend's?
    When did this drain start?
    Do you have optimized charging enabled?
    Charge phone to 100 and use till 15% Post battery drain graph and app usage stats
    @KirankReddy
    KirankReddy likes this.
  3. KirankReddy
    Eclair Jul 25, 2021
    Yess...drain started before 2.7.7 update..and two updates came since then and nothing changed...
    Yes it is enabled...sometimes I even put it on battery saver but not much use..and even I tried with 60hz and fhd display not much difference again...
    Data I wil send again here after using.....
    subsidiary likes this.
  4. G_plusone
    Nougat Jul 25, 2021
    Disable optimized charging.
    Should help with Warp Charging.
    Your friend hasn't updated their phone's software yet?
  5. KirankReddy
    Eclair Jul 25, 2021
    She got the phone one week back and it is updated one only
  6. KirankReddy
    Eclair Jul 25, 2021
    Will it reduce battery life?? As it is written while disabling it..
  7. G_plusone
    Nougat Jul 25, 2021
    Not necessarily.
    The battery health reduction when using Warp Charge and without Warp Charge isn't significant enough for you to go missing the fast charging feature.
  8. subsidiary
    Froyo Jul 25, 2021
  9. KirankReddy
    Eclair Jul 25, 2021
    Nope...it still took 36 mins to charge with data off and on ideal conditon ( I kept it there and just watching it charge..
  10. G_plusone
    Nougat Jul 25, 2021
    36 mins from 0 to 100?
  11. KirankReddy
    Eclair Jul 25, 2021
    Yes...1% to 100%...I saw from 60 to 80 it nearly took 20 minutes...from 1 to 60 it took near to 22 minutes ...it was actually more than 36 minutes...
  12. G_plusone
    Nougat Jul 26, 2021
    G_plusone , Jul 26, 2021 :
    What's the Ambient temperature?
    Was the phone hot when you plugged in?
    Anything less than 45 Mins for a full charge is alright I guess.
    Full charge in 30 mins was achieved under ideal laboratory conditions.
  13. KirankReddy
    Eclair Jul 26, 2021
    KirankReddy , via OnePlus 9 Pro , Jul 26, 2021 :
    The surrounding temp is 22°c and phone is cool when touched and used even. While charging the phone was on rest and didn't heat as well. Any reason of charger faulty or phone limiting the current flow or battery problem?
  14. G_plusone
    Nougat Jul 26, 2021
    You get a full charge in 40 mins?
    That's alright I think.
    Don't drain the battery so low so often
    superplus likes this.
  15. KirankReddy
    Eclair Jul 26, 2021
    I charge the mobile when it reaches around 30 %
  16. KirankReddy
    Eclair Jul 26, 2021
  17. KirankReddy
    Eclair Jul 30, 2021
    KirankReddy , via OnePlus 9 Pro , Jul 30, 2021 :
    Sometimes it takes more than 40 mins...like 1 hour also..
  18. satej1995
    Froyo Jul 30, 2021
  19. KirankReddy
    Eclair Jul 31, 2021
    KirankReddy , via OnePlus 9 Pro , Jul 31, 2021 :
    Yesterday it took more than 1 hour of charging time..
  20. #20
