Charging Time (USB Cables and AC)
  1. Reloaded
    Honeycomb Apr 10, 2015
    Reloaded , Apr 10, 2015 :
    So the stock charger with the oneplus (uk) supports 2.1amps (21000mA) so when i charge my phone i should be getting a near 2amp charging current but the charging speed is only 960mA but it should be getting near that 2000mA range for a fast charge because both the charger and oneplus support thoes amps.
    So I was wondering why is this happening (such a low charging speed) and what can I do to fix it like a better charging cable to support the higher amps. I have also tried this test at all battery percentages and I am using stock charger + cable and AC charging.
    M4ENY likes this.
  2. Reloaded
  3. TimCook
    lameking91 likes this.
  4. akhilseth
    Froyo Apr 10, 2015
    akhilseth , Apr 10, 2015 :
    It would be interesting to know why that is happening, I have had this question for a while too, I tend to charge my OPO with the stock charger at home and it charges quickly but also drains quick, but when I charge it at my work using a BlackBerry charger, it charges slow but doesn't drain as fast. I could be absolutely wrong about this. So, would be great if someone who has a bit more knowledge about this could shed some light..
  5. huwred
    huwred , Apr 10, 2015 :
    It would help if you provided the info for the question you are asking, you keep mentioning charge time, yet you have not stated how long it is taking to charge your phone !!! 960mA IS NOT a charging speed it is an amount of current
  6. brian2012
    Froyo Apr 10, 2015
    haybat likes this.
  7. haybat
    Gingerbread Apr 10, 2015
    haybat , Apr 10, 2015 :
    Because the cable supplied can't handle the voltage...
    Im using Hippo Teleport 45 cm cable and got 1,6 A output
    When im using Delcell Zaxti gen 4 cable, i got 1,3 A output
    When using supplied cable by OPO, only 900 mA delivered to my OPO
    brian2012 likes this.
  8. Niels_Andersen
    KitKat Apr 10, 2015
    Niels_Andersen , Apr 10, 2015 :
    What app do you actually use to see how high the mA rate is?
  9. Reloaded
    The mA shows how much current is going through so a higher current means a faster charge but the opo charger cable is charging at half that current. I was a nice looking (possibly braided) cable to sport the full 2amps of charge the wall charger can output.
    Nice but is there a 2amp option to support the full mA and braided.
    I use ampere
    what kind of mA? And its a gigantic thing I only need 1 charger.
    brian2012 and Niels_Andersen like this.
  10. lameking91
    Ice Cream Sandwich Apr 10, 2015
    Pucksurfer likes this.
  11. Reloaded
    To show how shit these charger cables are and apple lighting cables are the best!
  12. lameking91
    lameking91 , Apr 10, 2015 :
    So magnificent that they break at the joint every time? :p
    tyler539 likes this.
  13. Skf123
    Marshmallow Apr 10, 2015
    Skf123 , Apr 10, 2015 :
    I'm guessing you're seeing those numbers while your screen is on?
  14. Niels_Andersen
    KitKat Apr 10, 2015
    Thanks for the info.
  15. Reloaded
  16. Reloaded
    Yea thats how i measured it
  17. Skf123
    When the screen is on charging current drops by half. Download battery monitor widget and leave your phone in charge, it will show you a full history of how much your phone is drawing in while screen is off.
    ogriff likes this.
  18. Reloaded
    ok will do, but will it show the mA going through each percent
  19. Petar Vrshko
    Cupcake Apr 10, 2015
    Petar Vrshko , Apr 10, 2015 :
    Hi, I just receive oneplus one 64gb, and from the first call there was a problem, the other person could not hear me good and clear.. its on and off but still its here and its very frustrating . Please help me. and how do i report this issue and submit a ticket?
  20. Skf123
    It will look a bit like this
