Charging Time (USB Cables and AC)
  1. Reloaded
    Honeycomb Apr 10, 2015
    Reloaded , Apr 10, 2015 :
    Stop hijaking threads! Use customer support in the order page
  2. Reloaded
  3. Skf123
    Marshmallow Apr 10, 2015
    Skf123 , Apr 10, 2015 :
    No problem, tag me if you need anymore assistance.
  4. lameking91
    Ice Cream Sandwich Apr 10, 2015
    lameking91 , Apr 10, 2015 :
    Well I would not say I hate apple. They have their goodness and in fact I like their iPad more than our android tablets. They have each of their strengths...
    That charger....I'm not sure...normally I wouldn't use generic chargers and I believe the factory one is the safest ..
  5. Reloaded
  6. Skf123
  7. Reloaded
  8. Skf123
    Btw you need to start charging your phone at a low percentage, input current reduces dramatically after 80-90%
    brian2012 likes this.
  9. brian2012
    Froyo Apr 11, 2015
  10. brian2012
    Froyo Apr 11, 2015
    brian2012 , Apr 11, 2015 :
    They have many different types. If you only need one usb, buy that one. It's smaller. The technology allows any phone to charge at the fastest speed the phone allows. Charged mine in an hour the other night.
  11. M4ENY
    KitKat Apr 11, 2015
    M4ENY , Apr 11, 2015 :
    I was actually wondering about the same problem as well but a new cable fixed that :)
    The charger itself is only a part of the whole charging process. The cable is also very important.
    When you are looking for a new cable try to look for out for the "gauge number" for example 24/28 instead of 28/28 has 60 percent thicker gauge allowing more current to flow through. There are cables with 20 rating which in theory allows more current but with OnePlus 24 is more than enough (it's actually same as the stock cable that comes with the OPO)
    Another thing to look out for is the cable length. Good rule of thumb is the shorter cables are the better ones since the longer cables actually diminish the charging rate noticeably. Get one foot one and not three foot for example it charges alot faster.
    If you have any more questions feel free to ask :)
    brian2012 and Reloaded like this.
  12. T3STY
    Honeycomb Apr 11, 2015
    T3STY , Apr 11, 2015 :
    If you're using "battery monitor widget" app you should consider my issue: on my device if the screen is on, the reported charging current varies from 900mAh to 1100mAh. As soon as I lock it (so screen off) it will get 1800+mAh. With the OP cable I get it charged (from 15% to 95%) in 1h20m, usually (the charging rate is reported +56%/h).
  13. ninja9878
  14. Reloaded
    Reloaded , Apr 11, 2015 :
    Thanks for the info man! Really appreciate it!!!
    Same i had the same problem. Will watch out for that!
    And the lifetime insurance for crazy prices ;)
    Thanks will consider if i need a longer cable than the short opo cables.
  15. CaneDrew
    Gingerbread Apr 11, 2015
  16. haybat
    haybat , Apr 11, 2015 :
    Because you use extender, that's why the charging time is so slow...
    The shorter cable you use means faster charging time... Vice versa...
    I already have super high quality powerbank...
    I buy it in 2013 and still working good until now...
    Dual USB output, auto cut voltage and turn off when the smartphone is full, can charge even when the smartphone batteries is fully depleted (not all powerbanks can do this), and good build quality...
    Black Yoobao Transformer 13000mAh
  17. haybat
  18. haybat
    Cool...
    Ah... I almost forgot that when you using usb port at your laptop/pc, it takes 6-7 hours to fully charge the OPO from 10%
    #38
  19. jameskwx
    jameskwx , Apr 11, 2015 :
    For those who want to charge at full 2Amps while the screen is on, you can flash Render kernel. It has charge control which can overwrite the default behavior of only 1A while screen is on.
    #39
