4
Charging
  1. B1571190622579
    Cupcake Dec 12, 2019
  2. Matt 80
    Lollipop Dec 12, 2019
  3. nachhas
    Cupcake Dec 13, 2019
    ssagheer, Notorious18 and Matt 80 like this.
  4. B1571190622579
    amankrishna likes this.
  5. S1580466736209
    Cupcake Jan 31, 2020
    S1580466736209 , Jan 31, 2020 :
    yes same issue with me . wrap charge was working perfectly fine for initial 1 month .for past one week it's taking more than 3 hrs for a full charge .
    Amine Khadire and amankrishna like this.
  6. amankrishna
    Cupcake Feb 5, 2020
  7. Tarun Upadhyay
    Cupcake Mar 23, 2020
    Tarun Upadhyay , via OnePlus 7T , Mar 23, 2020 :
    did you guys got your issue fixed ?
  8. S1580466736209
    S1580466736209 , Mar 23, 2020 :
    No it's not fixed yet. I am assuming it has to do with I charged once with a charger other than the one provided by one plus in the box. This is still and speculation.
  9. Sheppards
    Ice Cream Sandwich Mar 23, 2020
    Sheppards , via OnePlus 7T , Mar 23, 2020 :
    I don't think so, I'm using a QC 3.0 charger and and the OnePlus charger around 40-60 % respectively, and have no problems with either.
    Isn't your phones overheating?
  10. rahulsawlani
    Eclair Mar 31, 2020
    Amine Khadire likes this.
  11. Matt 80
    Lollipop Mar 31, 2020
    Matt 80 , Mar 31, 2020 :
    Try cleaning your charging port, this is probably the most common culprit when it comes to charging issues.
    Still not working?
    If you have and friends or family who also have a warp charger, then try their's to see if it works.
    If it works you know the issue is with your charger and you can replace it, if it doesn't work you know the issue is with your phone and you can get it repaired.
    Sheppards likes this.
  12. D1580384618038
    Cupcake Apr 9, 2020
  13. S1522409760872
    Cupcake Apr 21, 2020
    S1522409760872 , via OnePlus 5T , Apr 21, 2020 :
    I have been facing similar issue, but if we switch off the phone and charge it fast charging is working
  14. S1522409760872
    am facing similar issue but if we switch off the phone and charge it fast charging is working
  15. Abhinay646
    Cupcake Jun 13, 2020
    Abhinay646 , via OnePlus 7T , Jun 13, 2020 :
    iam having OnePlus 7t. Suddenly charging is not working.i need to reboot device to make it work.sonetimes need to factory reset to charge my phone. Please suggest me how to resolve this in this lockdown situation.
  16. Amine Khadire
    Cupcake Jul 11, 2020
  17. Amine Khadire
    Amine Khadire , via OnePlus 7 Pro , Jul 11, 2020 :
    The same but there is any solution just make us wait ...
  18. andyleak84
    Donut Jul 18, 2020
    andyleak84 , Jul 18, 2020 :
    I have the same issue and my OnePlus 7t is only 3 months old. port looks pretty clean. sometimes I see it's not warp charging, although the phone does feel hot. there is no explaination on the phone that it's hot.
    cable also looks pretty new. started happening when I bought my bullet z.
    I think it's a software issue. England is plagued with this problem and has been for years.
  19. ssagheer
    Ice Cream Sandwich Jul 18, 2020
    ssagheer , Jul 18, 2020 :
    If you have a case, remove it and then try to charge. It might be that the case is preventing the charger from proper connection for Warp charging.
  20. E1570416373740
    Cupcake Jul 18, 2020
    E1570416373740 , Jul 18, 2020 :
    if the battery temperature is too high the warp charging doesn't work for safety purpose. Once battery is back to its normal temperature, automatically warp charging will start.
