Charging via OnePlus Nord
  1. Santhosh6604
    Cupcake Oct 28, 2020
  2. dpenov
    Ice Cream Sandwich Oct 28, 2020
    dpenov , Oct 28, 2020 :
    Can you clarify what you meant by not working properly?
    Auristic likes this.
  3. Santhosh6604
    Santhosh6604 , via OnePlus Nord , Oct 28, 2020 :
    When I put my mobile in charge .. It showed warp charging and within 5 min it stopped warp charging and it is like charging in data cable while we connect to laptop and took so much time . And also days before when connected in charger suddenly it will start warp charge.. but now it takes some time to start and also stops suddenly..
  4. dpenov
    There are multiple things to consider:
    1. Poor/unstable electrical delivery
    2. State of charge. The higher the battery percentage, the lower charging speed
    3. Usage during charging
    4. Temperature. I think warp charging works at temperatures below 30 something degrees. Otherwise it will degrade the battery
  5. Santhosh6604
    Okay done.. Thank u
  6. dpenov
    Also disable Optimized charging.
  7. Santhosh6604
  8. Santhosh6604
    I updated once in oxygen updater.. So I don't know whether future updates will come by mobile itself or by oxygen updater.. Can u please clarify me.. Becoz I saw a youtube video that version 10.5.9 came in oxygen updater
  9. Santhosh6604
  10. F1599205882544
    F1599205882544 , via OnePlus Nord , Oct 28, 2020 :
    This depends on the charging mode selected in Settings / Battery.
    If "optimized charging" is selected (the best option) the device+warp charger can stop charging at 80% and resume charging 6 hours later to preserve the life of your battery and the hour of charge ending is indicated in the drop-down menu.
    "Optimized charging" keeps in memory all your daily habits to ensure a proper maintenance of your device. Of course in the drop-down menu you can by-pass the software if you want an immediate full charge.
  11. Santhosh6604
    But sir .. I charged my mobile in 25% .. but it suddenly stopped.. again I charged it stopped in 35% and then once again I removed and connected
  12. kacamataafi
    Honeycomb Oct 28, 2020
    kacamataafi , Oct 28, 2020 :
    are you using your phone while charging? the very basic of power delivery is the charging will be slower if you are discharging (using your phone) while charging. plus warp charge will reduce the wattage of current flowing into your phone if the temperature increase.
  13. Santhosh6604
    No.. I never used my mobile while charging
  14. Santhosh6604
    Also one doubt sir.. I updated once in oxygen updater.. So I don't know whether future updates will come by mobile itself or by oxygen updater.. Can u please clarify me.. Becoz I saw a youtube video that version 10.5.9 came in oxygen updater
  15. kacamataafi
    you will still get ota thru system. dont worry.
  16. F1599205882544
    To put aside any hardware failure, a reboot in recovery mode with the selection "wipe the cache" (not the datas of course) could be a good idea.
  17. Santhosh6604
  18. Santhosh6604
    Sir but how to do that ' Wipe Cache '
  19. F1599205882544
    Shutdown your device. Device Off.
    Press Volume - / Power On buttons until logo appear... Wait...
    Select English >> Wipe data and cache >> Wipe cache >> Reboot.
    Of course no data loss.
  20. Santhosh6604
    Okay sir.. Thank u so much
