Charging via OnePlus Nord
  1. prashantsingh+
    Cupcake Oct 1, 2021
  2. camohan
    Assistant Head Moderator Assistant Head Moderator Oct 1, 2021
    camohan , Oct 1, 2021 :
    Hi there, I hope you are using original charging cable and adapter.
    Also go to settings, battery, and toggle off optimised charging, to see if this changes the eta.
    Also Please note this is only a estimate time, it can reduce later.
  3. prashantsingh+
    Cupcake Oct 1, 2021
  4. camohan
    How about the cable and adaptor question.
  5. prashantsingh+
    Cupcake Oct 1, 2021
  6. camohan
    Are, they original was the question?
  7. prashantsingh+
    Cupcake Oct 1, 2021
  8. EnCrypt3d , via OnePlus Nord Blue Marble , Oct 15, 2021 :
    I am also facing the same issue with my one plus nord. I tried doing the full diagnosis of my device through the OnePlus care app and it showed that the battery is working properly. I don't know why I am facing this problem.
  9. Niyas91
    Cupcake Oct 21, 2021
  10. Niyas91
  11. EnCrypt3d , via OnePlus Nord Blue Marble , Oct 27, 2021 :
    I had contacted OnePlus care regarding this issue and they asked me to do a troubleshoot on my device....the troubleshooting proved helpful and my charging and battery issues has been solved.
  12. Mohammed_Es
    Cupcake Nov 27, 2021 at 6:06 AM
    Mohammed_Es , via OnePlus 8T , Nov 27, 2021 at 6:06 AM :
    What's troubleshoot?
  13. H.S.S
    Ice Cream Sandwich Nov 27, 2021 at 6:00 PM
    H.S.S , via OnePlus Nord , Nov 27, 2021 at 6:00 PM :
    Just give a soft reset and once use the 100 percent battery of your device until it switches off and then charge it to 100 percent immediately. I hope this will resolve your issue.
  14. avil25
    Honeycomb Nov 28, 2021 at 3:04 AM
    avil25 , via OnePlus Nord , Nov 28, 2021 at 3:04 AM :
    For me its fixed after i remove cable from phone and plug it back. But i have to do everytime i have to charge. Before reading this post i thought i have a problem with my jack. Check for lighting sign on top if its there its charging fast.
    Fast charging
    Slow charging
