Charging
  1. Mohit Chaudhari Cupcake Apr 30, 2018
  2. Dipkyadav Gingerbread Apr 30, 2018
    JRFO and S1525066321001 like this.
  3. Chandra.Akhil Gingerbread Apr 30, 2018
    Chandra.Akhil, Apr 30, 2018 :
    Recent mobiles have mechanism to stop charging after 100%
    so don't worry, but my suggestion is not to do that again and again it may effect battery
  4. Hydra Bob Starting Point Expert Apr 30, 2018
    Hydra Bob, Apr 30, 2018 :
    It's fine like already said the phone will cut the circuit and go into a trickle charging mode when full. It won't cause any damage or anything but it will continue to charge a small amount as it drains so essentially you're going through a small percentage of a charge cycle over and over again which will reduce the battery's longevity if you make a habit of it.
  5. H1511704495267 Eclair Apr 30, 2018
    H1511704495267, Apr 30, 2018 :
    you just need an hour to full charge....then why you keep charging overnight..?? it's OnePlus dude.[e]1f4aa[/e]
  6. DARTH 007 KitKat Apr 30, 2018
  7. BHAUMIK.T007 Eclair Apr 30, 2018
    BHAUMIK.T007, Apr 30, 2018 :
    op5 takes an hour to charge
    and you charge it upto 6 hours while you are in sleep.
    that is overcharging.
    you gonna loose your battry life of op5.
    you must charge it when you wake up in morning, only an hour or 100 %
    both are same,[e]1f604[/e]
    Angela_Woods likes this.
  8. BHAUMIK.T007 Eclair Apr 30, 2018
    but why,
    if our phone takes only an hour to fully charge!!
  9. Chandra.Akhil Gingerbread Apr 30, 2018
    That's by mistake, not intentional
    BHAUMIK.T007 likes this.
  10. Matt 80 Lollipop Apr 30, 2018
    Matt 80, Apr 30, 2018 :
    It's perfectly fine, I always charge my phone overnight, and I've never had any battery issues.
  11. Chandra.Akhil Gingerbread Apr 30, 2018
    It may not show immediate effect but it will surely effect battery
    battery will won't last long if you continue to do that
  12. Matt 80 Lollipop Apr 30, 2018
    All batteries degrade over time no matter how it's charged.
    R1527954774592 likes this.
  13. Chandra.Akhil Gingerbread Apr 30, 2018
    I totally agree with you , but it depends on you, how long you could manage to get best of it
  14. nash6688 Gingerbread Apr 30, 2018
  15. BHAUMIK.T007 Eclair Apr 30, 2018
    you will get the resut aftre some time, few months.
    then you remember this comment.
    best of luck
    and keep charging overnight
  16. Matt 80 Lollipop Apr 30, 2018
    Since I moved from regular mobile phones to smartphones in 2010, not including my current daily driver I've had 4 long term devices, an HTC, a Sony, a Samsung and a Motorola. All owned for around 2 years each, all charged overnight on a daily basis and none of them suffered any issues or noticible battery degradation as a result. So no luck is needed. The whole charging battery overnight is bad issue is either, A: a myth, or B: completely blown out of proportion.
    MoWeb, debjit1990 and Hydra Bob like this.
  17. Chandra.Akhil Gingerbread Apr 30, 2018
  18. victorzmartin Honeycomb Apr 30, 2018
    victorzmartin, Apr 30, 2018 :
    charging every time, overnight will probably accelerates the battery degradation, but honestly, the effects will appear after 2 years. dash charge changed my charging routine... nowadays I put the phone to charge during my breakfast and morning shower... reachs 80%, Wich is enough for me
  19. BHAUMIK.T007 Eclair Apr 30, 2018
    that's exatly im doing
    when my phone charged fully in time when i get ready for work after wake up,
    then why do i charge overnight....
    victorzmartin likes this.
  20. BHAUMIK.T007 Eclair Apr 30, 2018
    everyone pretending like they use their oneplus when they brush, in toilet, in shower, wareing clothes after shower, breakfast......LOL
    [e]1f602[/e][e]1f602[/e][e]1f602[/e][e]1f602[/e]
