Charging
  1. borysall
    Gingerbread Aug 20, 2014
    borysall , Aug 20, 2014 :
    My OPO was discharged tonight and now i`m putting it on charging and color sensor doesn`t shine.
    Do you had the same problem? What have i to do?
  2. borysall
  3. baylward
    Gingerbread Sep 10, 2014
    baylward , Sep 10, 2014 :
    Here's the deal... I had the same issue until I found that you must orient the big usb plug into the power converter with the white side of the cord up with the logo side of the convertor. Mine is now charging....
  4. beginnersluck
    beginnersluck , Sep 10, 2014 :
    it doesnt shine if your phone was turned off while charging
  5. koldoff
    Cupcake Sep 30, 2014
    koldoff , Sep 30, 2014 :
    had same problem !!! phone just 3 days old! was up to put it on charge 3rd time , nothing happens indicator doesnt work , don't know what to do !!!!!???
  6. koldoff
    sorted , maybe that was just a luck after half an hour on the charge i unplug it and switch it back on, it was take a bit longer as usually but it starts up !!
  7. JesJessen
    Donut Nov 5, 2014
    JesJessen , Nov 5, 2014 :
    It seems that the problem is not residing with the charger or the cable.
    • I have tested the charger with a different compatible cable and the charging worked.
    • I have tested the cable with the charger on another /Samsung) phone and it was charging.
    • My OPO charges with the OPO charger and a (Samsung) cable.
    • My OPO charges using the OPO cable and a USB port on my laptop.
    • MY OPO does not charge using the OPO power converter and OPO cable.
    Conclusion. All hardware is working separately. Consequently the charging problem must reside in the OPO firmware.
    barlowrm likes this.
  8. srismisma
    Froyo Nov 5, 2014
    srismisma , Nov 5, 2014 :
    Hi @JessenC ,
    I have the same problem. I tried all the possibilities you mentioned, the result is same. I also suspect that the problem is in the firmware.
    srismisma
  9. Bhusha102271
    Gingerbread Nov 5, 2014
  10. ffaideau
    Cupcake Nov 20, 2014
    ffaideau , Nov 20, 2014 :
    Hey guys!
    Thank you for publishing this problem on the forum. I don't feel alone anymore : )
    I tried all possibilites: with the computer, with the adaptator but the screen doesn't turn on. It never happen before except this morning after using it until the battery reach 0%.
    Does anybody have a solution?
    Thx!
  11. Dacostarick
    Gingerbread Jan 17, 2015
    Dacostarick , Jan 17, 2015 :
    Yes, it is indeed a firmware problem and OnePlus has not really resolved this issue
  12. vathuluri
    Cupcake Mar 21, 2015
    vathuluri , Mar 21, 2015 :
    Hi Guys, Im having the same problem. Anyone found any solutions for this ? I tried different adapters and different cables and combinations of all. It still didn't work.
  13. Deactivated User
    Mar 23, 2015
  14. JesJessen
    Donut Mar 24, 2015
    JesJessen , Mar 24, 2015 :
    Please don´t question my logic. Thank you for understanding. Have a nice day.
  15. Deactivated User
    Mar 24, 2015
  16. fatfingers
    Honeycomb Mar 24, 2015
  17. JesJessen
    Donut Mar 25, 2015
    JesJessen , Mar 25, 2015 :
    I don't appreciate your personal comments so please find another playground.
  18. Deactivated User
    Mar 25, 2015
